New Saito 4 Cycle Gas Engine, 3 Cyl FG-84
Reply
Old 12-02-2017, 07:25 PM
  #151
CH Ignitions
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rcexl makes the Saito CDI.
so yes that did or CH will be compatible 100%.
Adrian
CH Ignitions is offline
Old 12-03-2017, 04:41 AM
  #152
Jim Cattanach
Jim Cattanach's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Adrian.
One last question before I buy a new ignition system. I hooked up my 3 cylinder Saito radial ignition module, attached a battery, removed the spark plugs & fitted them in the plug caps.
There are strong blue sparks at each plug. Is it possible there could be no sparks under compression?
I cannot get a pop out of any cylinder when trying to start the engine. Fuel is getting to the cylinders, as the plugs get wet.
Jim Cattanach is offline
Old 12-03-2017, 05:26 AM
  #153
CH Ignitions
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I may say 1 but not all 3 of them...
How do you connect the wires? the wires out from CDI falls on the engine naturally .
The wire in the middle is CYL #1 , right wire #2, Left is #3 and that is with you as a pilot in the "sit"
Not from the prop site.
Maybe is to much fuel that kills the spark, USE a 7.4 V Battery.
I have the CDI for those, Email me in case you need a new one.
Old 12-03-2017, 05:42 AM
  #154
Jim Cattanach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HT leads are on the correct plugs. I am using a 2 cell lipo with good charge.
It did start for a few seconds yesterday & idled perfectly. Advancing the throttle caused an eratic running like the spark was cutting on & off.
I stopped the engine to inspect the electrical connections. All looked fine, but it never started again after 3 hours of trying.
I am fairly certain it is some electrical problem.
Old 12-03-2017, 06:39 AM
  #155
CH Ignitions
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The cutting on off could be from too rich...but I am not there to see/hear.
Take plugs out and heat them out like in good old times on the stove to dry them up or put ne.
Reset the carb to factory settings.
If you have a RCexl tachometer use it to see if you get signal from sensor and start from square 1.
Old 12-03-2017, 09:04 AM
  #156
Jim Cattanach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Adrian for your help.
I changed the plugs twice. Carb adjustment was tried at factory settings & many positions around the proper settings.
Not one cough would the engine give.
I have ordered another ignition from the UK.
Once it arrives, I will post the results.
Old 01-27-2018, 10:21 PM
  #157
Jim Cattanach
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update. New RCEXL ignition finally arrived. Engine is now running perfectly.
Old 03-06-2018, 05:33 AM
  #158
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys.
My Saito 84 has been a great engine.
A bit difficult to start, but I have always just injected some gas into the open carb before each start.....a little annoying, but got used to it in my Yak 3U.
Now im in the process of installing it into my waco, and I had to remove the carb to remove the mounting place so I could install longer engine mount bolts........and then I saw a huge problem....
The carb spacer with the cutout for the pump vacume line was installed the wrong way around, so instead of vacume to the pump in the carb, it was actually venting to the atmosphere, and sucking in air........
Its amaizing that my engine ran without the pump....I cant believe it myself.. How can it run at all without the pump pulse ?
The very first time I started my engine ages ago, it was only running on 1-2 cylinders until I richened the needles......now it makes sense, as it was sucking in air before the carb, and running lean.......I did not think much of it at the time.....
I just counted and reset my needles. Manual says 4.5 on the low, and 2 on te hig needle. I have run mine at 4.75 on the low, and 5 on the high needle screw.
Unbelievable....as my engine was actually running great. :-)
I hope it runs just as well with the pump working :-)
ID:	2257844   Click image for larger version
ID:	2257845   Click image for larger version
SJN is offline
Old 03-06-2018, 06:07 AM
  #159
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are mistaken.
According to your,picture the pulse hole is located in the pulse channel. While the hole is not directly over the hole in the carb it is still allowing the pressure change necessary to operate the pump diaphragm.
Idealy yes the hole in the spacer should be directly over the hole in the carb.
BobH is offline
Old 03-06-2018, 06:15 AM
  #160
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no, the gasket/spacer was covering the whole channel.
I should have taken the pictures a few days ago when I found out, then you could clearly see only one indentation in the gasket on the opposite side of the gasket cutout.
I put it back together the propper way a few days ago, and now you see the indentation on both sides of te gasket.
SJN is offline
Old 03-06-2018, 11:21 AM
  #161
SWORDSN
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you been able to run it after correcting the problem?
SWORDSN is offline
Old 03-06-2018, 11:25 AM
  #162
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im still assembling the plane.
I have just reset the needles to factory........and test it when I can
This is how it ran before......i bet setting it right it will run like crap :-)
And here it was running for one of the first times with the factory needle settings out of te box..........and aparently the carb port blocked.
SJN is offline
Old 03-06-2018, 11:57 AM
  #163
BobH
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes I see the indent on the gasket on the other side from the hole.
All one can say is that their carb operates a little differently than a normal Walbro Carb or similar.
Apparently the pulse is not so critical for operation?
BobH is offline
Old 03-06-2018, 12:00 PM
  #164
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea, because normal walbro carbs dont work at all without the pulse.
But it did run great before....except the starting :-)
SJN is offline
Old 06-12-2019, 09:54 AM
  #165
EFHANC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SJN , are you still running your FG84R3 ? If so, how is it holding up if you don't mind me asking? I do own one but haven't run it yet. Thanks, Ed
EFHANC is online now
Old 06-12-2019, 09:58 AM
  #166
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still runs great. Going to fly again tomorrow
SJN is offline
  #167
EFHANC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, I should have asked is anyone still running their FG84R3 and how is it doing? Thanks, Ed
Old 06-12-2019, 10:03 AM
  #168
EFHANC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SNJ, Terrific, that gives me confidence to carry on with the program. Got some questions but I'll read the threads first. Thanks, Ed
Old 06-12-2019, 10:00 PM
  #169
tyor
tyor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
after 3 year Still runs great
tyor is offline
Old 06-13-2019, 12:18 PM
  #170
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another great day flying :-)
SJN is offline
