If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 7 of 9 FirstFirst ... 56789 LastLast
Results 151 to 175 of 218
  1. #151
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito FG57 Fourstroke
    Lunatics ain't bad company friend,specially with bathurst coming up
    Watch out for the ground eh?
  2. #152
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi ernie thats a big thing to consider am doing it now.I want to make sure that there is a lot of incoming air directed over the exhaust side of the engine been reading about that a lot.Anyone with pics is welcome to post them,will do the same with mine next week if i can get the bloody thing to work
  3. #153
    Ernie Misner's Avatar
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey pope, what planes are your mintors going on? I'll need a home for my DLE 20cc.
    Thanks, Ernie
  4. #154
    SrTelemaster150's Avatar
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Ernie Misner
    How do they keep the Saito gassers from running too hot on gasoline? Different valve seats or? Doesn't gas run hotter?
    Thanks, Ernie
    My testing W/glow ignition/glow fuel, CDI ignition/glow fuel & CDI ignition/E85 on an FA150 showed the following.
    Cylinder Head Temperature between the rocker covers @ the rear:
    CDI/GF +20*F from GI/GF + 150 RPM W/18X8 prop
    CDI/E-85 +60*F from CDI/GF - 350 RPM W/18X8 Prop
    CDI/E-85 +80*F from GI/GF -200 RPM W/18X8 prop.
    I woudld expect gasoline to run even hotter than E-85
    Club Saito #785 - FA91S, FA-115, FA150, FA180, FA180HC/BBC, FA200TI, FA300TTDP: All with CH Ignitions CDI/Glow fuel
    SIG BH #42
    - 1/3 Spacewalker, Rascal 110
    CUB BH #231 - Wings Maker 1/5 J-3 Cub
  5. #155
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the great data. E85 is ethanol free 85 octane gas? From what source?
    Thanks again, Ernie
  6. #156
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks again, Ernie
    E-85 is 85% ethanol 15% gasoline.
    You can FIND E-85 STATIONS HERE.
    It is higher octane & will tolerate higher compression & more spark advance. It does require about 30% more delivery volume than straight gasoline. An engine can be tuned for more HP on E-85 over gasoline if the compression ratio is high enough to take advantage of the octane.
    SIG BH #42
  7. #157
    Join Date
    Apr 2005
    goolwasa, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, Ernie
    Howdy Ernie , one is going in a phoneix katana and the other in a SF 60 size trainer. With the trainer Ive moved the fire wall back about an inch and with the battery and servos moved to the rear no added weight will need to be added.
    I must say the quality of the last couple of phoneix arfs Ive bought have been very good, theyve lifted their game alot . Cheers the pope
    Cheers the pope
  8. #158
    Join Date
    Sep 2003
    Shoreline, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just a quick update to the percieved bearing problem..... the bearing is fine, and the notchy feel is coming from the way the straight cut cam gears mesh with the crank gear. All is fine and it runs like a top!
    By the way, what planes are all you guys using this engine (FG57T), on. Mine is currently on a Great Planes Ultimate bipe 160.
    Mark.
  9. #159
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good news mate,if you are really fussy they can scare you sometimes eh?
    Good question mines in a blackhorse models edge 540 90".How does it fly your gp160?
  10. #160
    affas's Avatar
    Join Date
    Dec 2002
    Lier, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine is in a well used Carden Yak 54 for breaking in and are then going into my almost finished SisT FW 190
    Best regards
    Alf Hansen
    Norway
    http://www.modellflynytt.no
  11. #161
    kwik's Avatar
    Join Date
    Jan 2007
    kongsberg, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine is used in an ESM 50cc Corsair.
    I got the replacement ignition, 2 off them, free of charge from Advantage Hobby.
    Here are some pictures, in case anyone is interested. They seem to be an exact copy of the original ignition, I am afraid.
    You can see the RcExl logo on the third picture from left.(Lower right corner.)
    You can see that feeble spring in the fourth picture, in the center.
    So, this is the third ignition for this engine;
    -First the original, similar to this one.
    -Secondly the wrong version.
    -And thirdly this set.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1809485   Click image for larger version.
ID:	1809486   Click image for larger version.
ID:	1809487   Click image for larger version.
ID:	1809488   Click image for larger version.
  12. #162
    Join Date
    Mar 2006
    East Aurora, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have just installed a Saito FG57 Twin in my 1/3 scale Ercoupe replacing a Fugi 63. I made the change in the hope of reducing vibration which was effecting my twin vertical stabs. The engine started very easily with my large electric starter and ran well on a rich setting for about one tank of fuel. I am using the reccomended 20:1 mix with Stihl Ultra oil. The exhaust is quite messy and black. Using a 22by10 prop the engine appears to have plenty of power. I am wondering if I can get rid of some of the exhaust mess by leaning it out after break in or by using another oil.
    The vibration particularly at lower throttle settings appears to be less than the Fugi 63. The sound is very appealing.
  13. #163
    Join Date
    Sep 2003
    Shoreline, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Old Fart,
    It flies my gp160 ultimate very well!
    No real mods to the plane to get CG right. Smaller tank mounted aft, and radio battery mounted between wing and tail.
    It flies real smooth.
    I'm thinking about getting a large Decathlon later on for it.
    Mark.
  14. #164
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Me too plus a spare,i reckon i'll crash the first one cause it sounds so good
  15. #165
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: kwik
    Jeez mate don't half mean to be rude but whatya *****in at?? ignition systems for free which you don't seem that greatfull for and don't acknowledge some backup id t6he way i read it,apoligies if i went down the wrong track there.
  16. #166
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi j i like your descriptive powers when you explain how your engine is going so far.Swinging the benchmark 22x10 got 6500 easy then i overloaded it with a 24x10.The reason was the right cylinder ring would'nt seat and now the same black goo is coming out of both pipes the same although the right pot seems to run a fraction leaner.Had to run it hotter at full throttle than i liked and rich as well.I know the ercouple beautiful looking aeroplane.Running klots200 syn in mine @20.1.Hav'nt touched the low speed needle yet.
  17. #167
    kwik's Avatar
    Join Date
    Jan 2007
    kongsberg, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Old Fart, I bought the second ignitions for $222 x 2 . But they were the wrong type.
    The third set of ignitions ( its 2 of them) are free replacements for the second replacement.
    So, yes, I am happy with that, but only mildly overjoyed.
  18. #168
    Join Date
    Feb 2012
    Brasher Falls, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Old Fart
    ORIGINAL: kwik
    I think he had bad experineces W/the replacement EI systems too.
    SIG BH #42
  19. #169
    Join Date
    Oct 2011
    Frisco, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello all:
    I know this has been discussed, but perhaps someone could point it out to me or help me out. I'm breaking in my57t and one of the cylinders is dumping heavy black oil out of it. My white wing on my t-28 was black!! Anyway, I have about 1.5 tanks though it and I've been running it between 2 and 4.3k rpm. Note. I'm running it very rich. Probably 6.5 turn and +1 turn above factory on the low end.
    Other than the oil and that it's rich, it runs and starts on the first flip!
    Here's my setup.
    http://www.rcuniverse.com/forum/fb.asp?m=11250541
    Thanks for the help.
    James.
  20. #170
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What kind of oil are you running? No loose or vibration muffler or header pipes, right? They used to use a black assembly grease sometimes but I don't know if that would show up coming out of the exhaust so much. We do get some black residue when something is worn or wearing inside the engine or when they are simply breaking in.
    Ernie Misner
  21. #171
    Join Date
    Oct 2011
    Frisco, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm running klotz synthetic with castor. Yes all coupling are tight. I do get spit out of the other cylinder, but about 1% of what the other is producing.
  22. #172
    Join Date
    Jul 2002
    Tacoma, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Seems like that could be worrisome coming out of one cylinder. Try removing one plug at a time and comparing compression on the two jugs.
  23. #173
    kwik's Avatar
    Join Date
    Jan 2007
    kongsberg, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you mean its coming out in the exhaust, then mine has done that all the time, too. And many others has mentioned it.
    The first youtube video I found of it running showed us the case by holding white paper under the exhaust.
    One got blackened quickly, the other not.
    Here the problem is gone, after 4000 cc ( Thats 40 litres ! ) gasoline running through it, he says;
    http://www.youtube.com/watch?v=Or0zOk670H4
    His videos can be found by searching for
    herrisonwang FG-57
    on youtube.
    For Nudgers videos on FG-57, search for ;
    66nudger FG 57
    For those interested, you can find my FG-57 videos by searching for
    wikeroy FG-57
    on youtube.
    Mine still spits oil on one cylinder, and thats after 45 flights.
  24. #174
    Old Fart's Avatar
    Join Date
    Apr 2008
    Perth, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    James i think kwik is talking about "supermontanamike's you tube vids,please watch if you have time.It's all about his experiences flying an aeroworks supercub with the fg57 and he does it so well,enjoyable to watch.You will notice he gets just as nervous as we do when you first fire this engine up.
    Sooner or later i had to throttle it up and get it hot enough to avoid that tenative first stage "oh my God nothing is coming out of the other pipe" syndrome,good luck with your's mate
  25. #175
    sharam's Avatar
    Join Date
    Jul 2002
    SF Bay Area, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    The break-in procedure outlined in the FG-57 manual is quite unusual. Did you guys follow those steps?
    Trex 700 OS105 Vbar, Logo Xxtreme 800, Goblin 770
    TopFliteFW-190 DLE55, P-51 DA50, P-47 G-62
    CARF Tutor evojet160, CARF Hawk K-140
    CDF Huey Jakadofsky Turbine
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
