Saito gas engine mounts
My Feedback: (8)
IL
I have an fg-17 and the fg-14b. I have the fg-17 mounted on a plane with a nylon mount because the metal mount included won't work unless I rebuild the firewall at a different measurement because the included metal mount doesn't allow for any adjustments. Is it okay to use these Saito gassers with a Great Planes nylon mount?
Thanks, Jason
Thanks, Jason
RE: Saito gas engine mounts
ORIGINAL: corvettez06
Thanks, Jason
Thanks, Jason
If the Saito engine mount will not suit your installation, then you have no choice but to use a different mount. Just be aware that you may have to provide a larger exit holein the enginecompartment/bay for the hot air to escape after it passes through the engine cooling fins.
Roger
