Something strange happened at the field today
My friend was maidening his 50cc Goldwing Extra 330/ DA50 model today when shortly after takeoff on it's first flight the engine stopped. Luckily he was able to land the model safely enough, though breaking one leg of the CF l/ gear at the axle connection.
An inspection of the engine revealed that the 4 aluminium cylinder mounting bolts had all shared and only the spark plug being attached to the HT lead had kept the cylinder from coming completely loose. The cylinder and the rest of the engine is servicable but it will require a new piston and ring.
This makes me wonder what is the purpose of using aluminium bolts instead of steel bolts as most other engine manufacturers do, as if weight saving is the reason then the advantage of doing so at best must be miniscule.
Karol
Karol
1 Post
RE: Something strange happened at the field today
Aluminium ? No Way, Can't be!
The torque required to hold the bolt in reduces the tensile load the blt can carry. They WILL snap.
Must be a mistake. Engine should be sent back to the manufacturer unless the bolts were the idea of and fitted by the owner.
theres no way they DA would use aluminm bolts.... they may have been "silver" in color, but wdre actually stainless....not quite as soft as aluminum and not quite as hard as black carbon steel
ID
Karolh you are indeed correct in thinking the bolts are made from Alum. and anodized red. The back case bolts are made from Alum also. Only the prop hub bolts are steel in any DA 50-100 engine I have ever seen or worked on. Why there sheared off i'm sure was the fact they worked loose over time and the pressure from the piston and ring going up and down popped the heads off. Many don't know that pound for pound Alum is stronger than steel. The cylinder bolts doesn't require a great deal of torque on the bolts ,but they do need to be kept tight. Anyone that has the stock bolts (RED) in there DA engine, use a magnet on them and see for yourself.
http://www.desertaircraft.com/images...s/50-small.jpg
It is not all that strange to hear of the highly touted DA engine popping those pretty red aluminum bolts. I am acquainted with an expert flier who will use nothing other than DA engines and sends his engines to DA for annual check ups but, in spite of that, he had a cylinder pop off. He told me about his experience after I told him that I had read about DA's blowing their heads off.
ORIGINAL: Cyberwolf
Phew, I was beginning to think that I had forgotten what a red anodized aluminium bolt looks like.
Karol
ORIGINAL: Rocketman_
1 Post
Indeed.
Overtorqueinng an aluminium bolt is murder. The twist in the material increases the static tension in the bolt. When the engine fires the pressure rises and the tensile stress in those bolts can easily be exceeded. Correct torque is an absolute necessity.
Replacment of those bolts if they are ever removed, is an absolute necessity - aluminium work hardens and thus will get brittle with repeated engine cycles.
If this is true for DA engine then it's very wise to adhere to the recommended service interval for those bolts.
My Feedback: (12)
ORIGINAL: flycatch
I find it refreshing that there are those in this hobby who know what they are talking about.
Me too, unfortunately most dont, and is difficult to tell the difference
ORIGINAL: K-Bob
In fact, that is very strange to hear. More than likely some one had the head off and overtorqued the bolts when re-installing. DA suggests replacing them if you ever remove them.
Da engines have been around a long time
Surprised this has not been posted here before
Cylinder heads coming off and damaging an expensive piston and liner is never acceptable in my opinion for any reason
This truly is ODD
This truly is ODD
My Feedback: (19)
Strange this thread should appear just on the same day I'm replacing those pretty red bolts with steel ones on my older DA100. For those who have never examined a DA jug closely, the top surface of the cylinder retaining flange is angled quite a bit from what would be parallel to the mating surface. Those aluminum bolts have to conform quite a bit (that means bend) as the head contacts the surface and is further torqued to specs. If you ever remove one of these bolts the bend in the bolt just below the head is quite easy to see and is present on every cylinder retaining bolt. This is not uncommon for many of our cylinders regardless of brand but the steel bolts seem to conform to the task better than aluminum.
By the way, my guess is that the aluminum bolts are a carry over from the early 3W days when they used quite a few aluminum fasteners. 15 or so years ago, the aluminum bolts retaining my 3W 60 carb broke in flight with less than pleasant results so I have never cared for aluminum bolts ever since.
Do a few searches and you'll find the DA aluminum bolt failing problem is not uncommon.
1 Post
I'm just surprised that DA would still be using aluminium retaining bolts on the cylinder head. Sure it saves weight but it invites more problems than necessary.
Although aluminium may be stronger than steel per lb we still need UTS and toughness and unfortunately aluminium simply fails to deliver in these areas.
This one of those things I enjoy about the business of model aircraft. Why use aluminium? Only thing that comes to mind is galvanic corrosion. Perhaps as the thread goes on we shall find out. Thanks for the comments about a very good and interesting subject. Even us know it alls may learn something.
1 Post
Aluminium to aluminium won't really create galvanic corrosion concerns. More concerning is galling between the two parts as they vibrate at slightly different frequencies.
What can create galvanic corrosion is the steel spring washer usually used underneath the hex / socket head of the bolt. But I can't see DA making an amateurish mistake in this area.
I will replace my DA 50 cyl bolts with steel ones...coated with a touch of anti-seeze. I do not like any bolt made out of aluminum. Capt.n.
My Feedback: (100)
NY
Ive got five DA engines 50's and they all have aluminum bolts and when I orderd spares they sent new aluminum bolts You mess with the bolts youll blow your warranty
ORIGINAL: dirtyoldman00
Ive got five DA engines 50's and 85's they all have aluminum bolts and when I orderd spares they sent new aluminum bolts You mess with the bolts youll blow your warranty
My Feedback: (100)
NY
spare bolts were cheap like a 50 cents apiece but they were a bear to torque you need a long 5mm allen wrench Ive read in many old threads this happens alot I would say probally from fuel or mixture or ignition timing off it would have to back fire to blow the head off you definatally cant re use them
My Feedback: (19)
