If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
  1. #1
    Join Date
    Dec 2004
    Wasilla, AK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    DLE 20 Flooded
    New dle 20 floods and will nnot run any idea how it is filling the cyc with fuel have the mixture adjustment stock.
  2. #2
    Join Date
    Apr 2004
    Des Moines, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20 Flooded
    Cranking too much with the choke on. That will flood an engine every time.
    Other than that, if the carb isn't leaking gas into the venturi with the engine just sitting there, there is no special way it can flood all by itself.
  3. #3
    Join Date
    Aug 2008
    Waterford, Mi/Citrus Springs, Fl
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20 Flooded
    The plug that comes with them is junk under the best of circumstances. Have you changed that to a CM-6 yet?
  4. #4
    3136's Avatar
    Join Date
    Oct 2010
    Victoria, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20 Flooded
    ORIGINAL: n411x@hotmail.com
    Have you checked that you are getting a spark? As Ahicks said, make sure you throw the dle plug away and use an ngk. I don't know why the **** they make a nice motor then put a crap plug in the box.
    If you are using a kill switch make sure it's hooked up properly, maybe take it out to see if that's the problem.
    Also make sure you are useing the correct battery (fully charged) a 4.8v nimh/nicad is fine for the task.
    Maybe try an electric starter if you haven't already.
    Once running get your needles set and it should flip start easily.
    If you can't start it easily there is something wrong with the setup or components.
    To check the ignition and hall sensor is fine go to the gas engines sticky, Jedijody has a tutorial of how to test it.
    Let us know how you go.
    Regards Mark
    Balsa USA Brotherhood 11
  5. #5
    3136's Avatar
    Join Date
    Oct 2010
    Victoria, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20 Flooded
    Did you get it running yet?
    If so what fixed it?
    That info can help others if they have a similar problem, so let us know how you went.
  6. #6
    raptureboy's Avatar
    Join Date
    Dec 2005
    Kempton PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: DLE 20 Flooded
    I had this issue with my first one and it turned out to be a small piece of metal stuck under the float needle. It seems the Chinese don't believe cleanliness is next to godliness
    I can explain it to you, but I can't understand it for you.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
