Gas ignition options
Reply
Old 10-05-2012, 10:00 AM
KitBuilder
KitBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Gas ignition options
I'm in the market for a my first gas engine sized 26 to30cc in the next few months and I read about generally two types of ignition, Magneto and electronic. Is magneto used much anymore? And ... do all electonic ignitions advance timing as the engine speed increases. It seems I've seen "add on" module required for that?
I'm leaning toward a DLE only because they're a brand name and message boards seem to indicate few problems out of the box... as well being my first gas motor I'm not looking for a steep learning curve if it doesn't run fairly easily beyong normal break in issues, etc I've read other less expensive motors requiring filing here and drilling here to get them ot run right.
I'm very familiar with glow 2 and 4 storke and an avid builder and plan to put the gas motor in the BUSA 1/4 DR1 kit.
Appreciate any replies..
KitBuilder is offline
Old 10-05-2012, 10:23 AM
vertical grimmace
vertical grimmace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Gas ignition options
I had a Fokker DR1 for 9 years. It had a Saito 180 in it most of that time but I put a DLE 30 in for the last year of it's life. Great airplane, you will love it.
That being said, If I were to build another in 1/4 scale (I am looking at the new 1/3rd scale closely) I would put a Zenoah G38 in with the spring starter. I have this combo in my Fokker DVII and it works perfectly everytime. It would be a perfect sized powerplant for the tripe.
It is a mag engine and what is nice here is one less battery, kill switch to worry about. The DLE 30 is a good engine as well and would work just fine. THe DLE line are great and I own a 50, 30 and the 20. My 50 is the old DL model.
One thing, If you never listen to anything else I ever say listen closely to this about gassers......DO NOT use a stopper style tank with gasoline. Even Dubro! Get the fittongs to make a Fiji water bottle tank, or get a Bennett built tank. The screw on lids will never leak and make servicing the inside a breeze. This was the biggest problem I had when I was new to gas.
Good luck, you will love gas.
vertical grimmace is online now
Old 10-05-2012, 10:36 AM
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is purchasing the SASSYA (made in USA) ignition module for chinese engines an option?
Ernie Misner is offline
Old 10-05-2012, 10:49 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The DLE ignitions work just fine and DLE is distributed by Great Planes, sold by Tower and the other retailers, and supported by Hobby Services.
About the only thing worth doing to them out of the box is a Frank Bowman piston ring but thats nice not needed.
RC Extreme Power www.rcextremepower.net has replacement ignitions for DLE and others.
VG, I have a GT80 that I converted to electronic because those spring starters scare the snot out of me
BarracudaHockey is online now
Old 10-05-2012, 10:50 AM
Truckracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Ernie Misner
Syssa uses the Chinese built Rcexl ignition just like most other engines these days! The engine may be made in the USA, but not the ignition module! Buy it from Syssa or any one of many other sources.
Truckracer is offline
Old 10-05-2012, 11:01 AM
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Syssa engines use Rcexl ign. modules - the universal version that doesn't have any bad habits.
If buying a new "30" class engine today, I would go with the new 35cc DLE for it's rear exhaust configuration. DLE because it's easy to find support. Yes it's a little more money, but the upside is that it comes with a pitts type exhaust as standard (vs. those aftermarket ones costing 75-100) and the fact it will fit more cowls without hacking them up (a big deal to me).
ahicks is offline
Old 10-05-2012, 12:25 PM
KitBuilder
KitBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The zenoahs are to much $$ right now. I read the rcecxl ignitions allow for a much better / smoother / lower idle.. is that correct. I'm hoping to use the stock ignition on the DLE and not pay another 90 beans for so just to replace with something better. Maybe down the road but for now stock is my choice / option. I'm not concerned about the battery for the ignition and for the kill switch... I assume it's a simple as mounting a switch in the cockpit that i can flick on and off?
Old 10-05-2012, 12:38 PM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
RCexl all the way for smooth, trouble free performance. They are as reliable as electronic ignitions get. (Mag ignitions are ultra reliable)
pe reivers is offline
Truckracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: KitBuilder
DLE engines also use the Rcexl ignition. In fact, most of the Chinese and many other engines use this very reliable ignition.
You are correct, the ignition will require its own battery and on-off switch. In some cases, you can also use a IBEC or Ignition Battery Eliminator Circuit that powers the ignition from the receiver battery and also provides a means to shut off the engine from the transmitter. This circuit does not require an additional switch. But ..... for your first gasser I would recommend the separate battery and switch.
Have you read this thread yet? It will answer many of your questions.
http://www.rcuniverse.com/forum/m_8673009/tm.htm
Old 10-05-2012, 02:00 PM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There aren't too many engines to choose from out there with magneto ignition on them at this time. They have been going away gradually as the engines with electronic ignition systems are pushing them out.  Usually the magneto ignition engines weigh considerably more than a electronic igntiion equipped engine.  But there are some magneto equipped  engines that don't give up much in weight though.  But a heavier magneto equipped engine could be a big plus with certain airplanes that have a short nose on them, as that means you don't have to add much, if any, extra lead weight to it, to get the CG setup on it. A magneto system is very reliable and doesn't have a battery to rundown on you or need to be recharged either. But the electronic ignition systems can be really good and offer really good performance too. So it would be a difficult choice to choose between the different types in some cases.
earlwb is online now
Old 10-05-2012, 02:37 PM
AJsToyz
AJsToyz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
C&H makes a smaller ignition for these engines
AJsToyz is offline
Old 10-05-2012, 03:18 PM
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just my opinion, but thinking magneto engines might require a little more patience to start for a gas rookie?
ahicks is offline
Old 10-05-2012, 04:06 PM
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Magneto ignitions don't have any advance system though do they, just fixed timing? Don't throw wrenches at me or anything, just an honest question - the magneto setups don't still have points do they? If not they would have to be a hybrid magneto / electronic igniton it seems like.
Thanks, Ernie
Old 10-05-2012, 04:09 PM
mrbigg
mrbigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
G38 with a mag is super easy to start. I have OPs DR1 with said engine. Perfect weight for balance with all radio gear forward. Zenoahs too expensive? Did you add the ignition battery cost and hassle of charging? If you need electronic go with a ZP38. Same engine with electronic ignition but cheaper.
mrbigg is offline
Old 10-05-2012, 04:40 PM
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Buy a used one. Very plentiful. As most people want e-ignitions
Old 10-05-2012, 06:48 PM
OliverJacob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My gassers all have an electronic ignition. I have seen one (old) magneto engine and it was a brick.
They are good for a few planes, especially warbirds which often need the nose weight.
Zenoahs are very reliable, but their are more expensive and their igniton systems draw more current then others.
I have a 20 cc in a heli and this draws about 2 amps vs 0.5 amps in most RCexl ignitons. Not a real problem, bust something to watch out for.
I also have a 30cc DLE, which is a great engine, starts right up and is easy to tune. The price is very reasonable and this brand has become very popular, I am sure you will get spare parts for many more years.
OliverJacob is offline
Old 10-05-2012, 09:30 PM
bcchi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AJsToyz
It is CH-Ignitions now not C&H.Yes Adrian builds a smaller lighter IGNITION now.
BCCHI AMA 2500.
bcchi is offline
Old 10-06-2012, 03:05 AM
mrbigg
mrbigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ZP engines don't use the high draw ignitions that Zenoah uses.
mrbigg is offline
Old 10-06-2012, 05:09 AM
BadAzzMaxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
True, They now use RCexl ignitions. Also Saito uses RCexl.
Milton
Quote:
ORIGINAL: mrbigg
BadAzzMaxx is online now
Old 10-06-2012, 05:53 AM
cloudancer03
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
two good places!!!! valleyview rc for genuine and auality service! they are great with DLE's..and Todd syassa in connecticut. he makes a very very good 30cc gas engine.plus his igntion systems are second to none(IMO only).I am selling off the last of my 2 strokes before they are virtually worthless $$$ wise..my satios and os four strokes cost me dearly and I still enjoy them so regardless of whatever direction the hobby goes they will always be with me.
as for magneto versus electronic igntion.there is no doubt in my experience that electronic igntions are lighter and in the long run easier to operate.having said that and owing several zenoahs magneto is inexpensive and very reliable just a weight issue I guess.if weight is an issue with you go the igntion route.once a motor is properly broken in and maintained magneto's are simple and reliable. the first start up when its cold can present a bit of a challenge but after that its easy the rest of the day.
cloudancer03 is online now
Old 10-06-2012, 06:49 AM
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Ernie
I put a timing light on a Mb290 29cc gas enngine (with a mag) and too my surprise, they do have advance. Look up different brands of magneto systems...you will see that indeed it is true. Capt,n
captinjohn is offline
Old 10-06-2012, 08:46 AM
Truckracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: cloudancer03
And the Syssa ignition is made by Rcexl in China. Pretty much just a standard, off the shelf ignition for a CM-6 plug.
Old 10-06-2012, 11:06 AM
vertical grimmace
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Now that gas engines are being use used for more than just Giant IMAC type competition aerobatic models, the race for light weight is not so much an issue anymore. Scale and warbird models need the nose weight, so magnetos are welcome here.
It seems now if a smaller lighter E-ignition could be created, it could usher in a whole new small sized gas engine. Right now it seems the 20cc is about as small as you can practically go, having to carry the ignition and another battery. I know there is a 9 cc, but wing loading will go up unless a
bec is used for ignition as well. Somewhat of a sketchy prospect IMO tying the ignition power source to the radio.
Old 10-06-2012, 11:47 AM
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: vertical grimmace
Once you get your head wrapped around the single battery components and setup (IBEC or whatever), and you get a chance to use it a couple of times, the hassle of dealing with an extra battery (as well as it's weight) is something you won't miss for long...
You might check with CH Ignitions regarding the smaller ign. module?
ahicks is offline
Old 10-09-2012, 07:23 PM
KitBuilder
KitBuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MBRIG:
" Zenoahs too expensive? Did you add the ignition battery cost and hassle of charging?"
Dont have any issues with batteries or charging... I fly electrics and glow both using all sorts of batteries and I have the charger to handle it all so that cost is not a concern. Just seemed the Zenoahs were pricey and with one heading to college in and one in pvt school... I'm jus being frugal where I can.
The DLE looks to give me more motor for less cost. If only money wasn't an issue .
My understanding was with the magnetos the timing didnt advance or retard with engine speed but stayed constant as the magnets passed by??
All good info here... Im a bit away from the purchase but hoping Santa will pick one up for me so I can spend my saved up beans on the 1/4 DR1...
Reply
Display Modes
