RCXL Ignition for CRRC pro 26
Reply
Old 10-12-2012, 09:44 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RCXL Ignition for CRRC pro 26
I am having some issues with this new CRRC pro 26 engine I picked up lasy year and am just know getting around to testing it. I can get is to start OK and the low end seems good but I cannot get the engine to run up past half throttle. [:'(] I have checked the carb and it seems to be working OK. I have been told to replace the stock CRRC ignition with a RCXL ignition. If I do that do I have to play around with the timing or is it just a strieght swap out Any and ll help is greatly appricated.
jstanton is offline
Old 10-12-2012, 09:50 AM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RCXL Ignition for CRRC pro 26
Give these guys a holler
http://www.rcextremepower.net
BarracudaHockey is offline
Old 10-12-2012, 09:56 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried the link you posted and all I get is site that tells me the domian my be for sale. R U sure they are still in business.
jstanton is offline
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The CRRC ignition had tiny primary wires on the ignition and were easy to break
Your problem seems to be a lean carburetor
w8ye is offline
Old 10-12-2012, 10:02 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have opened the high end to over 4 turns out and it does not make any differance. Just to let you know the carb that is on my CRRC Pro 26 is the WT-747 carb and it had a factory default in it. There was a small hole that had to be drill in the carb diaphram cover to alow pressue back into the carb so it out pump full. I fixed that and it statrs up very early but no top end. That is why i was thinking it might be a defective ignition.[:'(]
jstanton is offline
Old 10-12-2012, 10:04 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also I am still using the torch spark plug the came with it. I am going to the auto parts store today and try and get a CMR7H NGK plug for it. That my help a little.
jstanton is offline
Old 10-12-2012, 10:25 AM
BadAzzMaxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BarracudaHockey
http://www.extremepower.net
Try this
Milton
BadAzzMaxx is offline
Old 10-12-2012, 11:07 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Milton,
Thanks that site worked and I am looking into it now
jstanton is offline
Old 10-12-2012, 11:10 AM
BadAzzMaxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To answer your question.
If you know the timing is right now and the sensor connector is a Futaba connector it is a straight swap out.
If not a
Futaba connector you will have to change the sensor and sensor bracket to the one that comes with the ignition, If timing is right now just mark the center of the original sensor and install the new one in the same place.
Milton
Old 10-12-2012, 11:29 AM
jstanton
jstanton's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Milton,
Thanks for your help. It souds easy enough so I thnik I will five it a try and order a new RCXL ignition for my engine.
jstanton is offline
Old 10-12-2012, 12:51 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jstanton
Huh? It works for me!
Old 10-12-2012, 02:06 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.extremepower.net gets you Jimmy.com in Cape Town, SA. They are a domain company.
The "RC" is missing from in front of extreme.
w8ye is offline
Old 10-12-2012, 02:16 PM
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jstanton
Milton,
Try [link=http://ch-ignitions.com]HERE[/link].
SrTelemaster150 is offline
Reply
Display Modes
