SV 26cc replacement prop hub
FL
The bolt holes are stripped on the prop hub for my SV 26cc. Does anyone know if there is a replacement part from a different engine that will work? The manufacturer doesn't carry a replacement prop hub for this engine anymore. Thanks!
RE: SV 26cc replacement prop hub
You can alternate metric with SAE and vice versa to drill and tap a hole the next size up without it getting too large. There is a SAE size bolt in between the 3mm and 4mm sizes and vice versa for SAE. So that way you can save the prop hub and reuse it.
If there is enough metal around the hole. You can drill it out a little larger and thread a brass rod to fit, use permanent threadlocker and screw in the brass insert. Wait overnight for it to cure good. You could drill and tap the rod before you thread the outer edge and then screw that into the hole. Then machine it off flat with the hub surface.
For those more talented, one can fill in the hole with aluminum solder and then drill and tap it to size too. But you have to heat it well and evenly to do that though.
FL
Thanks for all the helpful tips. Luckily, I found someone locally that is selling their old sv for parts yesterday. Thanks again!
