If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Apr 2006
    Perris, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    G-62 Flooding
    Hello I have a G-62 that runs at mid to full throttle but never reaches more than maybe 3000 RPM it's running super rich. I have had the needle valves turned all the way in and still has to much fuel getting into the carb. I rebuilt the carb and still the same issue. And I changed all the parts out and replaced them with new parts from a ZenG-62 rebuild kit. Still no changes. I tried a different Tank no changes. I can start the engine let it run for a couple of minutes stop it take the carb apart and fuel pours out it's soaked. I've had plenty of G-62's never had this issue. Any ideas. Please do no tell me to buy a different engine thats not going to happen
    1.I rebuilt the Carb.
    2. I Changed to a different tank (outside the aircraft)
    3. tried different gas (I have three G-62's a DA-100 A DLE-111 and a DA-150 and a Sacks 5.8 All run great on my gas oil mixture)
    Please help.
    Join Date
    Jan 2009
    Salinas, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    The rubber tip in the pop off needle is damaged? Did you use carb cleaner? It will eat that tip. Pop off lever set too high? The pulse diaphragm installed backward? The gasket on the pulse diaphragm on the wring side? Little flapper valves in the carb damaged or the fapper valve sheet installed in the wrong orientation? Try a different carb.
  3. #3
    ROGER RUSSELL's Avatar
    Join Date
    Dec 2001
    Jacksonville, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    If you have other G62's, try takeing a carb off of one that you know works and is tuned good and see if that cures the problem on this G62.
    When taking off the good carb take notice on how the gasket is situated, etc............
    Report back your findings
    Remember to FLY HARD and LAND SOFT
    AMA 5288
    IMAC 3721
    IMAA 24878
  4. #4
    flyinwalenda's Avatar
    Join Date
    Oct 2009
    Northeast, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    Assume it has the correct carb on it ?
    Did you check the float level setting ?
    Brian Ray
  5. #5
    Join Date
    May 2002
    Locust, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    I'd look at the fuel needle and replace it if you haven't already. It may be sticking open, or it may not be assembled correctly and causing problems. I hate changing them [:'(] because of that tiny little spring, but when all else fails, give it a shot.
  6. #6
    Join Date
    Jan 2002
    Carrollton, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    The rubber needle tip has to be damaged to be letting that amoutn of fuel in, or it is not situated on the arm correctly.
  7. #7
    Join Date
    Dec 2004
    hastings, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    Or the seat could be damaged, had that one
    Cheers Bob T
  8. #8
    Join Date
    Jun 2012
    mogadore, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: G-62 Flooding
    Could the flywheel have slipped ever so slightly causing a late ignition not burning the charge efficiently.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
