If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    Jan 2009
    Salinas, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    NGH 9cc user reports wanted
    I want to buy one. I am an engine guy so some fiddling around is OK. I see they are in stock and ready to ship at multiple vendors. How are they working out?
  2. #2
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: NGH 9cc user reports wanted
    I have three planes equipped with the 9cc gas engines. The first one I setup was in a Great Planes Big Stick .40, then one is in an Escapade .40, The third one is in  a .45 size low wing pattern plane (old classic style). The planes all fly just fine with the engines. The engine has about the same power as a .40 to .45 glow engine. The engines are not as powerful as a similar sized glow engine. If you want lots of power these engines are probably not what you are looking for. The engines though may or may not be plug and play for a user. You might have to do some mods to the pump/regulator unit. It depends. I am thinking about fielding a twin engine plane next with a pair of the 9cc engines.
    Now with the Ugly Stick I did modify the engine to use as small bore Walbro carb instead of the OEM carb and pump regulator. But this is a on going experiment. The engine does work well with the Walbro carb. You'll have to make a carb adapter to use a carb like I did on it. Plus you'll need a Fox prop extender for the front of the engine so the carb will clear the prop.
    The OEm pump/regulator does use standard Walbro rebuild kits so that is not a problem.
    There are a couple or three of threads out there already about the engines and what to do to mod the pump/regulator, so I won't repeat it again here.
    Club Saito #722, Sig Kadet Brotherhood #80, GlowHead Brotherhood #14,
    AMA # 928076
  3. #3
    jerdavis's Avatar
    Join Date
    Sep 2004
    Pine Grove, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The info in this thread is http://www.rcuniverse.com/forum/m_10693112/tm.htm. The last page is pretty much my experience. It has fuel draw problems at full throttle which I solved by replacing the pump diaphram and cutting some coils off of the regulator spring, readjusting the lever and replacing the diaphragm of the regulator.
    Still can't get the idle low and reliable enough. It seems to be either poor fuel draw or oil fouling of the plug. Gonna try cutting more off of the regulator spring and going to 25:1 oil ratio.
    High speed needle valve setting is very sensitive. 3 clicks between too lean and too rich.
    After struggling with "dirt" in the needle valve (my fault) and learning how to read and set the mixture, I got three good flights in a row yesterday. A good flight meaning 10+ minutes, touch and goes, and a taxi back.
    The power seems to be about that of a modest .40.
    So far I'm enjoying the challenge of setting it up to be a reliable sport engine.
    Jerry
    P-47 Thunderbolt Brotherhood #6
  4. #4
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wrote up some of my techniques in this thread here
    http://www.rcuniverse.com/forum/m_11263347/tm.htm
    AMA # 928076
  5. #5
    flyinwalenda's Avatar
    Join Date
    Oct 2009
    Northeast, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am considering one of these too and did read-up on it. Yes it seems there are minor issues but once you rebuild the carb,regulator and either move or isolate the regulator most of the problems are solved.
    Brian Ray
  6. #6
    earlwb's Avatar
    Join Date
    Aug 2009
    Grapevine, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Here is a short video of me flying the little NGH 9cc engine on my low wing sport pattern plane as depicted above. I did some low passes so I could use a Doppler shift program to gauge its air speed. I measured about 58 mph at the time. But in hindsight the RC Speedo App on my iPhone may be in error, some others like me feel it was going faster maybe around 80mph. I'll have to repeat the speed runs later.
    http://youtu.be/bii2_r-OHN4
    AMA # 928076
  7. #7
    Join Date
    Sep 2003
    FortalezaCearα , BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, i think i need to share my modifications.....its really easy.
    All i did was....
    1 - Trash the pump(not really just dont use it).
    2 - Plug the crankcase fitting(fuel tubing and a plug).
    3 - Install a pressure line from the muffler to the gas tank with a one-way valve to keep pressure in the tank(just like glow engine)(i've used a perry one -way check valve).
    4 - Tune your engine, its going to run really nice and idle excellent. NO MORE AIR BUBLES IN THE GAS LINE. AND PUMP TO MESS WITH.
    I've pictures if you want to see just send me your email address in a pm or here. thanks guys. ran two tanks without any problem.
  8. #8
    Join Date
    Sep 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i did those changes after spending almost two days trying to fight with the pump and engine to make it run. i was thinking abotu buying the metering spring, pump walbro rebuild kit etc etc etc. and i saw some videos on youtube that the guys was runing it without the pump and one of the videos there is not even a fitting in the crankcase. check the videos:
    http://www.youtube.com/watch?v=lnPbxfvq8v4
    http://www.youtube.com/watch?feature...&v=vzU-VI5RcSE
  9. #9
    Kentli22's Avatar
    Join Date
    Nov 2012
    hong kong, HONG KONG
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
