New Evolution 10cc gas engine
Reply
Old 01-24-2013, 07:21 AM
  #676
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Evolution 10cc gas engine
Gosh... I'm confused now. I thought under propping was not enough load on the engine and over propping was too much.
AA5BY is offline
Old 01-24-2013, 08:24 AM
  #677
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: AA5BY
That's right
underproping lets the engine rev at higher speed than desiraeble for best flow .
overpropping prevents the engine ever getting into best flow speed.
It's kind of strange but max HP occurs not at the same engine speed as max torque - in most cases
At max torque -the engine has processed the most fuel mix per cycle .
At max hp - it has processed the most fuel mix per minute.
How well the flow path is setup determines how well the engine does this.
A rotary valve engine is typically best two stroke setup BUT some reed valve engines do the job very well -for our purposes
some piston port engines also do the job very well.
A tuned exhaust two stroke always produces more flow but may not be desireable for sport flying -
The fuel used can alter the entire scene - A LOT - simply because th fuel to air mix changes as well as the desired compression for best results
on n on etc..
rmh is offline
Old 01-24-2013, 09:55 AM
  #678
coronabob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rmh
Quote:
ORIGINAL: AA5BY
That's right
on n on etc..
rmh,
Thank you very much. I have learned a lot more from reading your single post. Clear and short explanation comes only from true understanding.
coronabob is offline
Old 01-24-2013, 12:14 PM
  #679
BlackPowder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did my madian flight today at a warm 32 degrees and then 50 perfect weather for a madian slight breeze down the runway. My Avistar elite weights 7.7 lbs. Ran two tanks on the ground with the 10 x 6 prop. at 5000 ft, I did not want to try flying with that small of a prop not knowing the engine's power yet. Then I put on a 11 x 6 zinger, the engine was a bit on the rich side. Tuned it and it was spinning at 11,580 rpm. The evolution 10cc engine flies this 7.7 lb baby with no proplem, it is fast. Did not do anything fancy because I think it is still rich. Got two flights today. A question for those who have flown already, what are you using to keep the muffler screws tight with? Jim
BlackPowder is offline
Old 01-24-2013, 03:34 PM
  #680
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: BlackPowder
I don't use the muffler gasket, it tends to break anyway and leak of course.The gasket tends to let the muffler move a little bit and that contributes to the screws coming loose.I run the engine and heat it up. Then check the muffler screws and tighten them again. The screws tend to grow in length slightly when hot as does all the other metal parts too. But usually the screws tend to come loose when hot like that. Using a couple of lockwashers on the mufflers screws is a good idea, if they aren't already there with the engine.
earlwb is offline
Old 01-24-2013, 04:24 PM
  #681
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: earlwb
I don't use the muffler gasket, it tends to break anyway and leak of course. The gasket tends to let the muffler move a little bit and that contributes to the screws coming loose. I run the engine and heat it up. Then check the muffler screws and tighten them again. The screws tend to grow in length slightly when hot as does all the other metal parts too. But usually the screws tend to come loose when hot like that. Using a couple of lockwashers on the mufflers screws is a good idea, if they aren't already there with the engine.
After several tanks of gas, the muffler screws and bolt will remain tight. Just like the manual said they would. I also use red Loctite to help keep them snug. Be sure to occasionally check the idle stop screw, as it can also loosen up and fall out. They cost $1 to replace, and don't ask me how I know that already! []
Dave
FlatSpin is offline
Old 01-24-2013, 04:54 PM
  #682
rc34074
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rmh
Quote:
ORIGINAL: AA5BY
That's right
on n on etc..
Then it follows that by your rules we must only use the one prop that gets the best flow/hp/whatever thru the engine for the fuel and plane that you want us to fly.. So why don't you instruct Evolution and Horizon that their manuals and website are wrong and they should require only one prop for this engine for a certain fuel/plane/style of flying? The conversations and messages here show that they have good results from their testing but time will tell how good their engine really is. The control of engine quality will also make a big difference as we have seen with other engines, but I'm hoping that my 10gx is a good one .
Your theory sounds good but what is the point of using it to justify your earlier comments? This theory is fine but it sounds more like a theoretical dissertation than practical advice. Many engines end up being run very well being underpropped or overpropped and work very well for their owners in this hobby.
So I will just see how the engine runs in my plane, which is what many others will do.
Ed
rc34074 is offline
Old 01-24-2013, 05:42 PM
  #683
flyingninja
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well all i can say is that iam in love with this engine.i got my engine 3 weeks ago and finally ended putting it in a 46 size see bee model made by phoenix models. i went throu 2 tanks with a 10.6 prop like sugested and it ran and flew like a champ.finally a engine that i can count on good bye nitro and hello gasser lol 2 more tanks on a 11.6 prop and im free as a bird.[8D]
flyingninja is offline
Old 01-24-2013, 05:52 PM
  #684
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Flew the Seagull Funfly 3D again today a couple of flights. I'm really liking the APC 14x4 funfly prop on this airframe. Another plus that I've not previously mentioned is braking action is better in down lines and this in turn helps slow the plane much better when landing. Both landings today required some throttle in a moderate headwind.
I tried to take note of the throttle setting to maintain hover and while that is considerably dependent on installation, it seemed to be around mid stick. I received an rpm telemetry sensor today and when installed will try pass on the numbers as to how many rpms it takes to hold hover with the given prop and plane weight.
AA5BY is offline
Old 01-24-2013, 06:54 PM
  #685
rmh
rmh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rc34074
Quote:
ORIGINAL: rmh
Quote:
ORIGINAL: AA5BY
That's right
on n on etc..
Ed
Where did you get the idea that I care what you fly and or how you fly it ?
What I explained is not just a theory - it's how these things work- If the info is not of use to you -ignore it .
rmh is offline
Old 01-24-2013, 07:21 PM
  #686
freeonthree
freeonthree's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do they have other mufflers for it. I don't see that one fitting inside any scale cowl.
freeonthree is offline
Old 01-24-2013, 08:22 PM
  #687
rc34074
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ed
[/quote]
[/quote]
Will do that, as I already stated above
Ed
rc34074 is offline
Old 01-24-2013, 08:40 PM
  #688
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Performance is often based on speed but there are other criteria. Noise level, braking, flywheel action, and vertical torque come to mind and there may be others. In my airframe, speed is the lesser criteria... in fact too much speed is a detriment.
AA5BY is offline
Old 01-24-2013, 08:53 PM
  #689
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im not power hungry, im a slow scale/sport guy, but I do expect a smooth idle and transition, along with easy starts, low maintainance, and a complete line of spare parts for next to nothing and free shipping, Dennis
Old 01-24-2013, 09:05 PM
  #690
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: av8tor1977
Someone is likely to say that it wouldn't be safe to use muffler pressure, which might be true. AV8TOR
The idea of muffler pressure not being safe is amusing. One tried &b true way to safely weld on a steel gas tank W/gasoline in it is to run a hose from the exhaust pipe of a running engine to prevent explosion.
W/exhaust fumes in the tank, there will be no oxygen to support combustion.
SrTelemaster150 is offline
Old 01-24-2013, 10:29 PM
  #691
Hance
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well mine is ready to go. Snowing miserable [:@] outside right now though. Not sure when its going to happen.
DSCN0138 by Hance1976, on Flickr
Hance is offline
Old 01-24-2013, 10:32 PM
  #692
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ever thought about getting a set of ski's for it ? Dennis
Old 01-24-2013, 10:34 PM
  #693
Mpizpilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wonder how this would do in a .60 super sportster? I've got one unbuilt only because I've gotten away from glow completely. Weight should be 6-7.5 lbs. engine recommended is a .45-.61
Mpizpilot is offline
Old 01-24-2013, 10:45 PM
  #694
freeonthree
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would probably fly pretty scale, not grossly overpowered like alot people like them. Dennis
Old 01-25-2013, 05:28 AM
  #695
rcrobby82
rcrobby82's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hance,
What plane is that??
Quote:
ORIGINAL: Hance
rcrobby82 is offline
Old 01-25-2013, 07:18 AM
  #696
Hance
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sabre 47 from value hobby http://www.valuehobby.com/airplanes/...dy-to-fly.html
Hance is offline
Old 01-25-2013, 07:21 AM
  #697
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
prop size is usually preference to the flyer and style of plane...but the landing depends on plane set up..play with cg moving it back so plane can set better when landing..just make sure not go beyond factory cg marks....i ordered an evolution 10gx..hope i like it...
josephcraig is offline
Old 01-25-2013, 07:27 AM
  #698
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i thought that was value hobby..i have liked their planes for the price..can't beat them...
Old 01-25-2013, 07:34 AM
  #699
rcrobby82
rcrobby82's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hance,
Please let us know how the performance is on this engine/plane combo.
Did you have any issues with balance?
What size tank is that?
Rob
Old 01-25-2013, 08:00 AM
  #700
BlackPowder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you compair the Supersportster 60 to my Avistar Elite the diminsions are very close, other than high wing vs low wing. Your the builder so you can build it light. My Avistar is a little longer by about 7" and I had to put my batteries as far back as I could and added a few oz of lead to the tail to balance it. My plane at 7.7 lbs with a 11 x 6 prop is fast and has alot of power. Hope this helps. Jim
Reply
Display Modes
