New Evolution 10cc gas engine
#826
RE: New Evolution 10cc gas engine
I saw them onsale at Horizon for $99 a couple weeks back. Tough to pass up on that price. Only wish I hadn't jumped in first up and paid retail for it. Lol
#827
SC
yea i know the feeling,just ordered the hanger 9 katana 50 and got in thursday..two days after i ordered it,put it on sale for $99.00....imagine that..i have been looking at this plane for months.guess its good i did go ahead and ordered it..going to be discontinued..don't regret ordering it cause its a beautiful plane..gonna see how this little gas is gonna pull this plane..i think it will be a good flyer...weighed the plane empty and weighed 3.5..how much do you think it will weigh rtf? 6.5lbs?
#828
SC
Pete,
i have been heat cycling the engine on the stand..probably use 1/4 gallon of fuel..haven't maiden it yet ..will the engine clear up more in flight off the load after more breakin and the high side needle setting on 1 1/2 to 1 3/4,is that gonna have to be moved any afterwards from day to day ......Craig
#830
SC
thanks dude, i guess i had a brain fart on that deal ..i'm so used to glow engines..never flown gas engines.....i over looked where it talked about one click plus or minus after ...
#833
SC
hey guys,
i recieved my hanger 9 katana 50 this past week...now hobby zone has the last shipment for 99.00..not a bad price for a nice looking plane..thought about ordering another one for that price....
#836
ORIGINAL: AJsToyz
on back order , won't let you order!
#839
ORIGINAL: SkyPilot101
How soon do you think Horizon will grow this up to a 15cc mill?
Ed
#840
OH
Hi Ed al at J tech is going to make me two wrap around muffler so when I put these 10 s on my hanger9 b-25 but I want to break them on my mat chapmen 580 so no issues when on the war bird just take some pictures an they will make u what u want
#841
ORIGINAL: chandley43231
I have serious doubts about trying to work with Jtec - I spent LOTS of time with them (sent them dimensions, pictures, etc) trying to get a wrap around muffler for my Super Tiger 2300 to fit in the cowl on my World Models GS mustang (81 inch wing) and they decided they would send me an older design which DID NOT FIT. When I complained they acted like I had NEVER talked with them about it, and the wanted me to do all the measuring all over again. Turns out they had done this old muffler for someone else and had an extra on the shelf which is what they sent to me. Then they wanted me to pay them more money to fix the muffler they sent to me that didn't fit.
So the only way I will deal with them is if someone else works out a design and Jtec or someone sends me a drawing with dimensions on it so I KNOW it's going to fit before I send them any money. Once burned twice shy I say.
Thanks anyway.
#842
ORIGINAL: josephcraig
Dave,
i think you said you was gonna try a different high side needle valve..did you try it how did it work?
craig
Dave,
craig
Dave
#843
SC
Dave,
do you think the factory needle is the way it is for a reason...i'm in the process of of putting my plane together on hanger 9 katana 50..i've run my engine some on the test stand..can't really tell on the stand until the engine is off the load..i did take some 320 sandpaper and knock the edge off the high side needle on the end...i'm gonna run it the way it is for a while to see how it adjusts...what blades have you tested and which size you like the best far as performance ...12 x 6 in the manual says best all around...
#844
Dave,
Dave,
On the 8lb Meridian airframe (dry weight, no fuel), my Evo likes a 12x6 APC the best. I flew it with a 13x6 and it worked pretty good but you could tell there was a performance decrease in aerobatic "snappiness". I think 8lbs is about the "performance limit" for this engine. I've also put the Evo on a 7lb trainer with a 11x7, 11x7, 12x6, 13x4 and 13x6. On that plane, the 12x6 and the 13x4 was the best match. I have a good 60-75 degree vertical climb out with those props.
Dave
#845
SC
YEA Dave,
i have run mine on the stand for about 1/4 gal and it seems to do really well..i made sure to get the temp up over 180 degrees and it seems really impressive on the stand..i have the hanger 9 katana 50 to put it on..the bare frame weighs 3.5,so hopefully i want be all that heavy when completed..i am gonna use life batteries so hopefully that will help some on the weight and gonna put pitts muffler on it and that will shed an ounce or two..my thinking is the pitts muffler will be more suitable for a gas engine..i'm not really clear why they went this type of muffler..i guess to keep from having to make different ones...i'm really excited about the first flight and hope i'm not dissappointed ..its really strong for a gas engine its size... i will let you know how the first flight goes after i do my maiden....thanks ...craig
#846
My Feedback: (65)
I talked with Al @ JTEC this morning about making 2 wrap around style pitts mufflers for my hanger 9 B-25. I will be sending him one of the engines for making these mufflers. If anyone is interested in getting one or two made he will have something to refer to. My distance from prop hub to the rear side of my mounts will be 4-3/4". He mentioned he would like to use 1-1/4 OD chamber but mine will only beable to use 1". The price is around 80.00 for one. I have had one other custom pipe made from them for my jba 15 that turned out very nice.
Jason
Jason
#847
SC
thanks for the offer,
i'm mounting mine in the horizontal position with exhaust coming out the bottom.i'm hoping the pitts is gonna work well for me.....do you have any pictures on these mufflers?
#848
My Feedback: (65)
I dont have any pictures, I am going to send the enginein the next day or so. I was planning on inverted, I was wondering if the horizontal muffler would lose any power?
#849
SC
i don't know,i talked to the horizon guy Jimmy,and he said they tried the pitts and didn't think there was any performance drop..i use them on the glow engine...ive noticed most of the gas engines having small canister mufflers on them..don't know if it will be the same for this engine since its the same block assembly as glow engine..just have to experiment i guess..i might have to order the extention so i can run the factory muffler cause i can't run it without extented it some...
#850
hi Jason(Kork) i will be chasing two inverted style pitts mufflers for my engines(once i get them) as i intent to mount my engines inverted into the blackhorse aerocommander shrike.
