New Evolution 10cc gas engine
Reply
Old 02-19-2013, 05:40 PM
  #901
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Evolution 10cc gas engine
yall hit the settings on the carb..once the engine gets temp up she is really great...
josephcraig is offline
Old 02-20-2013, 08:21 AM
  #902
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pete,
the filter in tank, will i have any problem on inverted flight,cause right now the line is still a little stiff...
Old 02-20-2013, 09:40 AM
  #903
Pete Bergstrom
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: josephcraig
Pete,
Joseph,
We have had no issues with the tubing being too stiff when we were testing. We used mostly 8 oz tanks and would suck the tank dry in all attitudes. Our test with a six ounce tank worked fine as well.
Pete
Pete Bergstrom is offline
Old 02-20-2013, 03:17 PM
  #904
Kentli22
Kentli22's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have more than 10 flights so far, with an apc12*8, everything is great except it is still making a lot of black goo,  what is the problem? i believe that I have the neeedles adjusted pretty correct  for this prop.
Kentli22 is offline
Old 02-20-2013, 04:19 PM
  #905
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Kentli22
The infamous "black goo" will eventually subside to a managable level. I am on my 2d gallon of gas and now using Klotz synthetic oil and the "goo level" is MUCH better.
Dave
FlatSpin is offline
Old 02-21-2013, 10:50 AM
  #906
Beavis
Beavis's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is there any black muffler from Macs that fits on this engine (and works well, of course)?
Thanks in advance,
Beavis is offline
Old 02-21-2013, 12:42 PM
  #907
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Beavis
Thanks in advance,
I am using the black MACs muffler that is designed for the OS 55AX. It is an exact fit and it works fairly well, with a 200-300 RPM increase over the stock muffler (in my case anyway). It softens the noise some, but mainly it is one piece and there is nothing to vibrate loose or fall off.
Dave
FlatSpin is offline
Old 02-21-2013, 01:30 PM
  #908
airborne2.4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use that same muffler with my OS 55
airborne2.4 is offline
Old 02-21-2013, 01:48 PM
  #909
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
what kind of rpms you getting with 12 x 6..is that your preferred blade...i ordered the evo blades i like the looks of them and think they should be just as good as apc...
Old 02-21-2013, 02:33 PM
  #910
kork
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just spoke with AL@ JTEC mufflers. He is making 2 wrap around pitts for me, for my b-25. The engines will be inverted, so if anyone has any questions you could call him. He has my 10cc mounted on a set of rails for measurements. It will be there all of next week.
jason
kork is offline
Old 02-21-2013, 03:59 PM
  #911
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
If I remember correctly, I am getting 11400+/- on the ground and 12800-13200 in the air.
Dave
FlatSpin is offline
Old 02-21-2013, 08:14 PM
  #912
flyingninja
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi flat spin on your black macs muffler is your muffler for the os 55ax a bolt through or a bolt on.the muffler on my engine keeps turning no matter what i do and its making the goo much worser on the plane.i would like to try the single one piese from macs if its not going to affect the tunning of the engine and contain the goo some to some extent.thanks for your info
flyingninja is offline
Old 02-24-2013, 06:16 PM
  #913
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i did get the bottom notched out for the muffler..the pitts would probably perform just as good ,but i like the factory muffler for sound and response.weather here has been crappy and i was sick a couple of days this past week..hope to close everything up this next week and see what it'll do.. i never get in a hurry to put one together cause i want to make sure everything is right..hope everybody is doing well with engine..i did order the evo blades and gonna try them ..i wish they made a 12 x 5, cause i like the 5 pitch..soon as i'm finished i'll take pictures,hopefully they won't be the last pictures...jimmy and pete, see if you can have some input on 12 x 5 evo blades....thanks
Old 02-24-2013, 08:29 PM
  #914
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: flyingninja
The MACs is a bolt thru muffler. I used red RTV on the original muffler body parts to seal it and a small o-ring on the bolt that goes through the muffler. That kept it from leaking from the middle of the body. I got the o-ring at the local auto parts store.
Dave
FlatSpin is offline
Old 02-25-2013, 02:16 PM
  #915
chandley43231
chandley43231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just got back from the field took the evo 10  up on my matt chapmen eagle 580  used the 10x6 prop for first flight wow took a bit to get off the ground  everyone was impressed  Jearad who flys hellis  for horrizon took up the 580 an thought i was empressive with out a sag  the black goow was just all over the left side of the plane  im going to try some dish washing soap to get it off they couldn't believe  that you have to run it at high rpm for break in all was such a perfect day at dennein field the wind was even running strait down the run way so as to have no cross winds  put 32 ozs through engine now im going to step up a prop  ill have post of the bird on u tube at chandley43231 great motor horizon good job man
chandley43231 is offline
Old 02-26-2013, 05:05 PM
  #916
hoss22193
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so for the black goo that is talked about has anyone found the best way to keep it from producing it. or is it just a trade mark of this engine.
hoss22193 is offline
Old 02-26-2013, 06:15 PM
  #917
FlatSpin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: hoss22193
Engine run time is the solution. Except for the fisrt several minutes setting up the needles and minor pit time associated with each flight, all of my engine run time is in the air. After the first 1/2-2/3 gallon, I noticed the amount of goo produced getting smaller and smaller. I have several flights from of my second gallon of gas and it is quite manageable now. That and I switched from Pennzoil air cooled 2C oil at 20:1 to Klotz synthetic oil at 25:1. It cleans up easily with a 409/ammonia solution or Clorox wet wipes.
Dave
FlatSpin is offline
Old 02-26-2013, 08:24 PM
  #918
Mikola
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
this thread is half dead, why don't you post more videos ? didn't it get success ?
Mikola is offline
Old 02-27-2013, 02:48 AM
  #919
chandley43231
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Krud cutter from lowes and Home Depots  it works with a little elbo  this motor will be great on my b-25
Old 02-27-2013, 04:32 AM
  #920
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Mikola
Sorry... having too much fun flying it to mess with videos.
I've got twenty some odd flights on mine and still have abt 1/3 gal of gas left in the can. Fuel cost are going to be around 15 cents per flight. No dead sticks yet. Easy hand starting. No glow starter or field box support needed. Cleans up with a single Clorox wipe so no roll of towels and spray bottle needed.
It will hover a 5.7lb plane at half throttle. It can be propped for fast or not as fast and thus will serve a wide variety of air frames. Video isn't needed to show success... take users at their word... it is a good engine.
AA5BY is offline
Old 02-27-2013, 06:37 AM
  #921
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just bought one of these based off of the "rave" reviews that its been getting . Its going to start out life going into a phaeton II, and then when my GP RV-4 .40 sized is done it will go into that. Can't wait!
mattnew is offline
Old 02-27-2013, 06:38 AM
  #922
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
my plane is gonna be a pound heavier than that..it should fly it pretty well then..don't you think?
Old 02-27-2013, 09:07 AM
  #923
chandley43231
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heck yea my gp  Chapman 580 eagle is just over 7 pounds its fly's great even with 10x6 starting on it  just moved the prop up to a 12x6 first nice weather ill be at the field again running the heck put of it
Old 02-27-2013, 10:32 AM
  #924
josephcraig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I figured it would..i haven't had time to finish my plane..seems like there always something that comes up..hopefully not long, try to work on it this week..sometimes too tired after work day..i'll keep you posted..my plane should be in that 7 lb range...keep you posted
Old 02-27-2013, 01:17 PM
  #925
silverwings
silverwings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have read this entire thread and this seems to be what I am looking for. I have a Goldberg Anniversary edition J3 cub on floats I purchased at a swap meet a couple years ago and would like to install a small gas engine. I was going to try the ngh 9cc, but it had such bad reviews, I decided against it. Then I happened upon this thread and it seems this engine is exactly what I need. I do not know what the weight of the setup I have is as I am not at home right now. I am in the snowy state of Iowa visiting my new granddaughters. I will be heading back to south Texas this weekend and will check it out when I get home. Does anyone have an opinion on this setup? From everything I have read, I think this will work for my application. I am not looking for all out speed or 3D, just some good old-fashioned relaxed flying off water and maybe some mild aerobatics. After all, it is a Cub. Thanks for any input.
Rick
silverwings is offline
Reply
Display Modes
