New Evolution 10cc gas engine
#1352
RE: New Evolution 10cc gas engine
AA5BY.... +1 is all I'll say.. I'm confused by Evegny's posts... if you asked me to summarize I'd say he hates the engine b/c he modified the crap out of it and it turns 16k rpm on a 13x6...
I'd be curious to see a poll of people that ACTUALLY own this engine and their satisfaction.....lots of opinions on here by people that won't even try it..
#1353
I've had my EVO 10cc installed in a vintage (80's) VK Cherokee. It performs flawlessly. I've been R/C modelling since 1964 so that's my experience bona fides. I would highly recommend the 10cc engine to anyone. Output power is incredible. The only small flaw was in the gasket materiel provided for the muffler. It needed to be thicker so that it would compress better. That's a pretty minor complaint. I did the break in using NON synthetic oil(red container StiHL). After a gallon of gas I switched to STIHL synthetic(silver bottle, and there's less residue.
Today I fired up the latest EVO engine, a 15cc, and the new muffler is bulletproof, no leaks. It started right out of the box with only opening the HS needle 3 clicks. I'm still in break in mode, but it is turning a Master AirScrew 13x6 at 10,280 RPM and reliable idle at 2900, this after 16 ounces of fuel through the engine.
I know there are tinkerers out there that like to see if they cannot wring something more out of the Manufacturer's product. Problem with this is that its like saying you're a brain surgeon cuz you got a good nights sleep at the Holiday Inn. There are many reasons that certain paths may not be taken, cost, wear, reliability just to mention a few. IMHO, this is one of the best engines to come along in the past 25 years.
KKKKFL
KKKKFL
#1355
ORIGINAL: mattnew
You have to take the troll's comments, who don't own this engine, with a grain of salt.
Dave
#1357
must be tough seeing the ground from up there...
You had an engine that wasn't tuned properly. Multiple people tried to help you tune it.. you ignored them and talked down to them.. even though they had the EXACT same issue you had at the beginning... you damaged the needle valve by doing exactly what the instructions tell you not to do... and the instructions tell you that doing it will damage the needle valve.. .. complained some more.... then supposedly did a bunch of modifications that now have the engine running with some ridiculous numbers yet offer no real proof.. we ask for videos and you post an MDSengine idling with a tachometer on it.... If thats called being a modeller... by all means.. you go be a modeller and I'll be a user.... I'll also be the one flying my scratch built planes this weekend.
ORIGINAL: Evgeny-arm
In the world there are two types of modelers - the users.
These are the ones that use only all ready.
And those who are constantly experimenting and doing something for yourself and are looking for something new.
I am not a user - I modeller ....
I am not afraid of view of the machine or not treated metal.
I am different from you - therefore this reaction from most of you.
You are afraid to live.
You used to think that someone is behind you.
You are used to that someone will do for you.
#1358
Apologies to the thread... and "rant off"....
Evegny if you enjoy modifying engines... by all means go for it, and by all means enjoy what you do and share your results here. It would be even better if you would show us what you did so that others could enjoy these performance gains as well....
Just realize there is a difference between me "choosing not to" and "can't"... I have an almost 7lb plane with a 10GX in the nose with not quite but near unlimited vertical, a nice idle and decent transition between .... I don't see a reason to modify the engine.
#1359
SC
yea, my plane weighs little over 7 lbs. and it pulls it really well also straight up unlimited...amazing for gas its size...curious to see if they do any changes on later 10gx engines..i will definitly buy another one..
#1360
I've just about had it with the google translated russian about marriage and life.
Now, what I would like to hear about is the engines that apparently are eating up the crankpin. I'm looking into one of the 20cc gassers, but those reports of busted crankpins within the first gallon got me thinking I'll probably be beta-testing for Evolution if I buy one of these.
Anybody have any info about how big the needle bearing in the 10cc is, and how it stacks up to the 15 and 20cc engines?
#1361
ORIGINAL: Rudeboy
Now, what I would like to hear about is the engines that apparently are eating up the crankpin. I'm looking into one of the 20cc gassers, but those reports of busted crankpins Within the first gallon got me thinking I'll probably be beta-testing for Evolution if I buy one of these.
#1362
SC
i think it was just a few that had the problem with it...i think it was all because of too much idling when it was new with the abc engine...the 15 and 20 are ringed,so i don't think you will have any problems...
#1363
OH
Gang try a master airscrew 11x6 3 blade on this bad boy an check out the pull increased rpm s I took a APC 13x6 prop off and wow what a boost next ill try a 12x6 masterwork screw all getting ready for my hanger 9 b 25
#1370
Just had another good weekend with the 10GX. I have about a half gallon through the engine now and started leaning out the low speed needle valve a bit. Transitions aren't perfect, but I've been very cautious on leaning out the engine too much and admittedly always run my engines err'ing on the rich side. Will continue to lean it out as I go further... I'm currently only a screwdrivers blade width leaner than stock and the response is instantaneous enough that I'm pretty happy with the results.
Had my first deadstick... flew the plane up to around ~450-500 feet and cut the engine and put it into a spin... engine died when we were down around 75 feet off the ground ( doesn't surprise me.. that was a pretty long spin... )... landed, went out to the runway .. fired the engine up with a couple flips and went right back up... Good stuff, I'm having a great time with the engine. Another flyer here has a 55AX on a similar plane and I'm pretty sure that the 10GX is outpulling the 55AX
I'm getting 10650 rpms on a master airscrew 12x6 fiberglass prop.
The one thing I do notice is the engine seems to "burble" a bit more when the muffler side is "up". I have my engine side mounted with a pitts muffer.... inverted flight causes "burbles" however the engine hasn't quite becuase of this. Any thoughts on this?
#1371
SC
fuel pressure changing i think..little gasoline engines are more touchy to it..you might try running a higher idle on the flips,thats what i do,cause it can upset it more with low idle..i had my first spark plug die on me this weekend..it would run but couldn't tune it..ive had 4 gallons through it,all the rich running from break in..
#1372
ORIGINAL: mattnew
The difference in rich/lean between upright and inverted indicates a difference in tank height when compared to the centerline of the carburetor. Most likely your tank is located below the centerline when upright andconversely above when inverted which then richens out the mixture. As you further dial in the needles the severity of the mixture change becomes less. If you have a way to shim the tank up a little higher in the fuselage when it is upright I think you will find that will help as well.
Pete
#1374
Its your Bison Pitts muffler... so down low when upright, and up high when inverted.
It could be fuel tank location... I think my fuel tank due to the planes design is about 1/4" lower than the carb. Not a whole lot I can do there.
My other thought is it could be b/c I'm using a 6oz tank and therefor short tubing...... I may be pulling the clunk out of the gas and getting some air bubbles in the line b/c of it.
ORIGINAL: flyinwalenda
My guess would be : where is the muffler pressure nipple positioned when the plane is upright versus inverted ?
#1375
ORIGINAL: josephcraig
Dave
