My first gas engine DLE 20
Another safety issue. Need a on-off switch to the ignition on the airplane, on-off toggle switch on the transmitter, and full idle and idle trim to kill the engine. Remove the Idle Adjustment Screw.
My Feedback: (19)
And .... servos use so little power to pull or hold against the spring it isn't really an issue. Several people (including myself) have performed the tests and published the results in various forums. In my opinion, there are several valid reasons for just leaving the spring as supplied and few valid reasons for disconnecting it. Zero reasons for removing it. Removing it can cause long term damage to the carb as the throttle plate can wear into the carb body. On many carbs, the spring acts as a spacer to locate and control end play on the throttle shaft.
Years ago, I use to remove or disconnect springs until I saw the error of my ways. Now I just leave them as supplied.
My Feedback: (9)
Agree I should have been more clear; removal = disengaging, at least for me.
I suspect, if your linkage geometry is dialed, and you running a quality servo, then disengagement prolly not required. On smaller airframes appropriate for DLE20, many use less capable servos, so I've disengaged in this case.
YMMV
YMMV
My Feedback: (9)
I'm not going to end the throttle spring debate. I did however hook all of mine back up. At last years fly in I had a DLE30 powered 3DHS Edge 540 break the throttle linkage at about 40% power.( it's got 9 lives but that's another story) I did inside/outside loops for 20 minutes while it ran out of gas. I really thought it was going to come apart. Any build up of airspeed at that throttle setting would have fluttered the elev and cost me the airframe. Maybe this will start a ignition cut off debate, but if I loose linkage again I know the engine will die.
David
David
