New Evolution Engines!! 15GX, 20GX, 33GX
Old 06-17-2013, 05:55 PM
  #101
ARTP47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Evolution Engines!! 15GX, 20GX, 33GX
anybody know why evolution does not want you to use Amsoil in there motors
ARTP47 is offline
Old 06-18-2013, 03:38 AM
  #102
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've now run all four of the GX series, 10-33 and like them all. The two smaller are good offerings in a small field of players whereas the two larger have a strong field to compete with where any engine must first run well and then have some edge and for the 20 & 33 it might be that they offer gas power without the bark.
AA5BY is offline
Old 06-20-2013, 04:12 PM
  #103
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I could use some help tuning the 15GX
I set the high speed needle out 1.25 turns as stated in the break-in procedure and started the engine. Ran a tank through the engine as stated switching from 1/2 throttle to idle. at 1.25 turns out the engine runs... however it runs pretty poorly. After the first tank I followed instructions for step 2 which was to set the needle so that you get your top rpm. at 1.25 turns out the rpms are around 5000 at full throttle and very very rich... I don't start getting good rpms until my high speed needle is turned all the way in, at which point I'm getting around 9500 rpm with the break in prop. Its still quite obviously very rich, but I'm not sure what to do from here. The instructions from what I've seen don't mention the default settings for the low speed needle so I have no idea if that is what is off...
After tank 2 I've stopped, since I obviously need some "pro" direction on where to go here. The engine starts easily and seems to run well... but I can't seem to get the high speed set correctly and don't want to damage anything.
Advice?
mattnew is offline
Old 06-21-2013, 01:26 AM
  #104
Lifer
Lifer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it runs with the needle closed you have an air leak. Contact Horizon, they have excellent customer service.
Lifer is offline
Old 06-21-2013, 03:09 AM
  #105
fat frank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About to mount a 33GX on my 1/4 scale super cub. anyone tried hi8s yet. Looks like I have to move the engine forward or fabricate a different muffler.
fat frank is offline
Old 06-21-2013, 05:07 AM
  #106
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on the service.....ive had great response from them...
So...air leak....meaning around the high speed needle valve? I can try to seal that with some tubing and see if that makes a difference.....
ORIGINAL: Lifer
mattnew is offline
Old 06-21-2013, 06:56 AM
  #107
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank... yes, the muffler requires a sharp break of the fire wall not far below the mount. Take the plane to the band saw... ye-haw.
AA5BY is offline
Old 06-21-2013, 11:28 AM
  #108
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tried tubing, same results.
ORIGINAL: mattnew
ORIGINAL: Lifer
mattnew is offline
Old 06-21-2013, 11:51 AM
  #109
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it runs with the needle closed, the problem would not be an air leak but rather trash at the needle holding it from closing all around. Remove the needle and flush and inspect for any debris.
AA5BY is offline
Old 06-21-2013, 07:06 PM
  #110
bcchi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mattnew
After tank 2 I've stopped, since I obviously need some ''pro'' direction on where to go here. The engine starts easily and seems to run well... but I can't seem to get the high speed set correctly and don't want to damage anything.
Advice?
Set the low speed needle the low speed needle will effect the high speed needle setting.If you had a air leak engine should go lean not rich.Lean low seed untill engine stumbles and wont take throttle then back out untill engine will take throttle.You may have to open high speed needle
after setting low speed .The engine may be to lean where you have it set now.Learn how to tune you carbs.Many posts on RCU on how to set Walbro tyoe carbs. Throw the book away.
BCCHI. Used to be C&H ,AMA 2500
bcchi is offline
Old 06-22-2013, 10:22 AM
  #111
mattnew
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
@bcchi
my problem here was the manual gives 0 indication of what a good starting point for the low speed needle was, so I had no idea if I was in the ballpark, that coupled with a line in the manual that says " the engine will run regardless of if the low speed needle is set correctly or not... meaning you can be extremely far off and still have the engine run, albeit poorly. So I was looking for some defaults as a starting point to make sure it wasn't just set incorrectly at the factory.
that being said.. I did figure things out and get it running, and running well...
@AA5BY
You hit the nail on the head... pulled off the needle valve and found machine shavings that prevented the needle from seating. Cleaned them out and reset the High speed needle and everything runs great now. Now I'm currently 1/2 a turn out from fully closed and getting right around 10k rpm, decent transition.. took my plane flying and had 5 great flights today.
The Engine runs well and pulls hard. I have it in a .60 sized UltraSport that weighs 7lbs ready to fly and I'm getting much better performance than I used to get with an O.S. 91 Four Stroke. The one hangup I've found so far is the same issue that others had with the 10GX and the muffler loosening in flight. I need to get some copper sealant on it... I did try tightening everything hot but it still appears to loosen up in flight. Not a big deal for me...
mattnew is offline
Old 07-02-2013, 07:36 PM
  #112
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew the 33GX again today and am beginning to conclude that the best course for at least the 20 and 33 GX is to rely on a starter. While they sometimes can be hand started with ease, too often they will burn off a choked mixture and not find a condition they are happy enough with to fire up. I've not made the change yet from the 20:1 to a 32:1 mix, which might ease starting difficulties.
They start easily with a starter albeit the 33GX benefits from a Dynatron.
AA5BY is offline
Old 07-17-2013, 01:45 PM
  #113
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Evolution 20GX gas engine powered GP Stuka is almost complete. I am looking forward to the engine break-in and maiden flight.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
ID:	1901533   Click image for larger version
ID:	1901534   Click image for larger version
ID:	1901535   Click image for larger version
ID:	1901536   Click image for larger version
ID:	1901537   Click image for larger version
Heli-NuBee is offline
Old 07-17-2013, 04:02 PM
  #114
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heli, that Stuka is gorgeous!
Let me ask you all about the Evo ignition units. Do they appear to be advantagous over the RC Exel or other ignition units in any way? Weight? Voltage requirements, advance curve, or? Just wondering if they would be a good replacement ignition for other engines.
Ernie Misner is offline
Old 07-17-2013, 04:15 PM
  #115
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The ignitions are a more compact version of RCexl.
AA5BY is offline
Old 07-17-2013, 04:27 PM
  #116
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well this is a very good thing. What is the input voltage?
Old 07-17-2013, 04:48 PM
  #117
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4.8 - 8v
AA5BY is offline
Old 07-17-2013, 05:04 PM
  #118
Ernie Misner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well heck, I like these Evo ign. units already. Anyone checked a price on them?
Old 07-17-2013, 05:31 PM
  #119
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.horizonhobby.com/products...ne-EVOE10GX#t4
Looks like $70
AA5BY is offline
Old 07-17-2013, 05:45 PM
  #120
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put one on my satio FG 20 with the C&H conversion. Very happy with the results.
rhd-RCU is offline
Old 07-18-2013, 01:35 PM
  #121
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I completed the odds and ends on the GP Stuka today and the plane is ready for the first engine break-in run. I plan to run the Evolution 20GX gas engine tomorrow.
ID:	1901879   Click image for larger version
ID:	1901880   Click image for larger version
Old 07-20-2013, 06:01 AM
  #122
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I performed the ground break-in run yesterday on the Evolution 20GX gas engine powered Great Planes Stuka. A short clip from the break-in run is shown in the video below. Sorry for the poor quality but I had to shoot the video alone with a cell phone.
http://www.youtube.com/watch?v=0Exj5DvbuF0
Heli- NuBee (AKA Roger the radial rabbit)
Old 07-21-2013, 11:10 AM
  #123
Heli-NuBee
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the maiden flight of my Evolution 20GX gas engine powered Great Planes Stuka today. I had two good flights and things went very well. The plane flies quite well and the engine perfomed perfectly. The engine has plenty of power and most of the flights were at about half throttle. So far, I am very impressed with the engine. Sorry but, no video, I just have not been able to find someone locally that can video a flight without all blue sky and sound only.
Old 09-18-2013, 10:48 PM
  #124
Chewy 76
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey fellas,
I was wondering if anyone had thought/or has jammed the 33GX into the Hangar 9 Taylorcraft. I have the Zenoah G26ei installed currently, but would like a little more oomph so to speak. Plus the 33GX is a tad lighter.
Chewy 76 is offline
Old 09-19-2013, 03:06 AM
  #125
AA5BY
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is a couple of tads more powerful... but not as easy to hand start. Ought to work well.
AA5BY is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
