Some experiences regarding Saito FG-57 after using it a while.
#104
And many are resorting to 15:1 to avoid siezures on the radials.
#105
I'm using 20:1 stihl ultra hp and it seems to really like it. When my engine arrive I took the rocker arm covers off check the valve and lube the mess out of it since it was dry from the factory, the guys at the airfield pick on us people who oil our engines up before use every week but our engines don't seize up or have rusty bearing so there you go.
#106
MN
I'm just starting to break mine in.
Using Johnsrud chain saw oil 20:1.
The left cyl is running very cool, while the right one seems to be doing all the work.
I measured the temp on the exh 90degree fitting.
about 100 F on the left and 150F on the right.
Have tried leaning and richening the hsn, same ratio either way.
If I richen it way up for break in it's worse.
Have not looked at the plugs yet, but know what I'll see.
Is this normal?
Is this normal?
#107
Pete, it seems to me you can fix that, within limits, with the L needle.
But I think you will have to accept a "certain difference".
#108
MN
Right, but this such a big difference I was concerned if I should continue running it that way, or get some advice on it?
It was better when I first started it with the factory settings, but the manual says richen it up for break-in.
Worried that the left cyl being so cool, it would break-in different than the right one.
Temp can be important in seating rings etc...
#109
Pete i hav'nt touched the needles on mine it pulls the right revs on the benchmark prop with good transition.You should be getting more oil out og the lefthand cylinder as it seems to run richer initially.After a while this went away on mine.If you can find 'montana mike' he fly's a big aerowoks cub and has posted vids on you tube.It will settle your nerves as it did mine if you watch them.
cheers
pete
ps hi kwik
cheers
pete
ps hi kwik
#111
Yes, guide-tubes.
If you have a Focke Wulf, you could reach the trumpet via the gun-hood.
Here is my Vailly Aviation Focke Wulf with the FG-84 ;
Hi Old Fart !!
https://www.youtube.com/watch?v=Cph9HMFfQqE&list=UUgI3jd4Z3cfjQKyisx5bArw
Hi Old Fart !!
#113
I wonder if anyone knows what the type-name of the FG-57 Walbro carburator is?
One of mine wont start now after a year not being used. So for example the Walbro of the Zenoah G-62, and the Vallach 120 cc is Walbro HDA-48D.
I need the type name in order to try to find a repair kit for it.
Typical the repair kit for the HDA-48D is called K-22, and you can then replace the membranes, and get it to start again.
My Corsair wont start, and the flying season is here.....Help!!!
#114
My Feedback: (16)
It has the Walbro label and it has a Walbro number. But . . . .
It is a proprietary Saito Carburetor. I don't know about the Saito factory, but Horizon wants you to buy a new carburetor for $157.50 and it is on Horizon's perpetual BACK ORDER No gaskets or any individual carb parts available from Horizon.
Try Walbro WYK parts? http://www.davesmotors.com/walbro-K1...33-58-194.html
This link is for reference
http://www.davesmotors.com/walbro-wy...arburetor.html
#115
My Feedback: (16)
I have a FG-36 and seems like I remember it being some sort of Walbro WYB-??
Look carefully around on the carburetor? There should be a sequence of ID
Look at the rubber parts of a K10-WYB repair kit?
At any rate there was never any consideration by Horizon that there would ever be a need for a new regulator diaphragm in a Walbro carburetor?
#116
My Feedback: (16)
With later diaphragm carbs, the pump diaphragm is made of Mylar and rarely goes bad.
But the metering valve regulator diaphragm is made of black rubber and is the usual culprit when it get to where you cannot adjust your carburetor.
What I'm saying is that likely all you need is to match up the proper shape of the black rubber metering valve diaphragm and install this part in your carb?
There are also WYC and WYL Walbro barrel carbs
npirzamani (06-03-2020)
#117
Here is a carburetor that is being used to convert FA-180s to gas. It should have a Venturi of the proper size for he FG-57 as the FG-57 utilizes FA-180 pistons so the bore/venturi ratio should be correct.
http://www.ebay.com/itm/new-Zama-car...item2ee0eb6e4f
Replacement parts are readily available.
http://www.ebay.com/itm/RB-75-Genuin...item27e8ea23dd
I have several of the C1Q-P8s that I was going to use for E-85 conversions but I abandoned that idea due to the scarcity of E-85 north of the corn belt. I would send you one for the cost of shipping.
I can measure the Venturi if you like.
#118
My Feedback: (16)
The previous post left out some explanation.
The situation is that the Saito twin is a alternate firing twin and not simultaneous firing like a two stroke opposed twin.
Therefore, the proper size carb is one for just one of the two cylinders. Thus the carburetor the proper size for a 180 gas Saito should be correct for a FG-57.
#121
My Feedback: (16)
The Stihl 4-mix weed whacker engines comes in 28, 32, and 36cc variants and they all have the same carburetor
The part number is Stihl 4180-120-0604 C1Q-S110D Trimmer Edger Carburetor FS90 FS100 and the are available from your nearest Stihl dealer and are all over Ebay.
I would look for a new one for less than $38
#123
#124
Yes, I dont buy such things from Horizon.
I guess I will have topull my engine out from the cowling and look for the type number on the carb then.
Open complaint to SAITO;
You must state the type of carburator in the Manual !!!
