SAITO FG 84 R3 RADIAL GAS
I have been able to run close to a half gallom of fuel through engine and so far no issues. The motor runs beautifly! Not a super power house but pulls the aircraft well. The model weighs probably 25 pounds plus and will pull the model vertical for awhile and the hold. I am running a 24x10 zoar wood 2 blade on it. I have a lot of nice compliments on the motor. I look forward to putting it on my scale project.
QC, CANADA
what is the rpm with the 24x10?
#34
Guys ..just started making saito gas baffles in carbon..
what do you think..http://rcmodelcomposites.com
#36
Thats the bold size. The prop needs to be drilled to 12mm. The shaft in back of the threaded part is larger on the 84RG. I started with a 10mm>11mm>11.5mm and then the 12mm to get a good fit for the Beila 12X22 three bladed prop.I got the metric drills from Drill America on Amazon.
#37
My Feedback: (8)
#39
My Feedback: (36)
ID
Just got mine back from Ray English after he did the con rod and fuel distribution mods, it runs awesome! Beila 22-12 triple, 6100 RPM's, it's going in a Top Flight Focke Wulf. Using Cool Power Synthetic oil as per his recommendation, it slobbers a lot like a slimer, but that's a good thing, it's getting plenty of oil blown by the rings to the rods. Oils like Redline burn too good and aren't a good thing in a 4 stroke. Running the Cool Power in the 84, 57, Valach and Moki Radials, great stuff! Horizon has it.
Tom
Tom
