Homebuild petrol engine
Old 02-10-2015, 12:05 AM
  #76
av8tor1977
av8tor1977's Avatar
Man, the bragging rights are worth a lot too! Being able to say "I hand built the entire engine from metal stock". Yeah! I can just imagine the thrill when the engine starts for the first time!!
AV8TOR
Old 02-10-2015, 12:48 AM
  #77
dubs1946
Fantastic old school skills amazing stuff.
Dave.
Old 02-10-2015, 01:20 AM
  #78
jef-lemmens
Thanks guys for the positive comments , it gives me even more pleasure to working on it and to hear the engine running for the first time
Kind regards Jef
Old 02-10-2015, 05:52 AM
  #79
Muttdog
Simply amazing.
Old 02-11-2015, 04:45 AM
  #80
Cyberwolf
Cyberwolf's Avatar
Yes you are correct the first fire up on a home built engine is the best but so are all the rest of them as well *L* Reliable with maybe more power than any factory engine in the same size is nice also.
Old 02-11-2015, 09:48 AM
  #81
Truckracer
My Feedback: (19)
Originally Posted by captinjohn
That sure is a crude not nice thing to say. First you do not know his abilities & 2nd some people love doing their own work. It is vey satisfying to them. Maybe what you say is not worth saying........
Captin, I think Zagnut was actually paying the OP a compliment.
Irony with a bit of sarcasm.
Old 04-12-2015, 10:37 AM
  #82
jef-lemmens
It's a while ago but the engine is almost finished , the ignition clamp piece , the cover for the transferports and the inlet manifold are ready now it's waithing for the ultrasonic cleaning device that I ordered so I can clean the carburetor
Greetings Jef
ID:	2088368   Click image for larger version
ID:	2088369   Click image for larger version
ID:	2088370   Click image for larger version
ID:	2088371   Click image for larger version
ID:	2088372   Click image for larger version
ID:	2088373   Click image for larger version
ID:	2088374   Click image for larger version
ID:	2088376   Click image for larger version
ID:	2088377   Click image for larger version
ID:	2088378   Click image for larger version
ID:	2088379   Click image for larger version
ID:	2088380   Click image for larger version
Old 04-12-2015, 10:53 AM
  #83
av8tor1977
av8tor1977's Avatar
Just absolutely amazing. So very cool!!
Only one comment/suggestion. It doesn't appear that the prop collar that holds the magnet is keyed to the crankshaft. You might consider doing so, as sometimes a prop hub like that can slip and throw off your ignition timing.
Wow!
AV8TOR
Old 04-12-2015, 03:02 PM
  #84
karolh
Absolutely amazing work Jef, you ought to feel quite proud of your creation ..... I know that I would.
Karol
Old 04-12-2015, 08:16 PM
  #85
the pope
awesome . wish i could do dat . Well done from the pope
Old 04-13-2015, 07:38 AM
  #86
jef-lemmens
Thanks everyone for the comments
@ AV8TOR , I have taken that into consideration but I was concerned that the crankshaft would weaken at this point , but the prophub sits firmly on the crank , at disassembly I have to use a pulley puller ,( I don't know if this is the right word)
Regards Jef
Old 04-14-2015, 06:55 AM
  #87
PLANEIAC
PLANEIAC's Avatar
Awesome Work!
Old 04-20-2015, 07:11 AM
  #88
jef-lemmens
Originally Posted by PLANEIAC
Awesome Work!
Old 04-20-2015, 07:14 AM
  #89
jef-lemmens
It needs some fine tuning but it runs https://www.youtube.com/watch?v=4kuj...c_location=ufi
Greetings Jef
Old 04-20-2015, 09:13 AM
  #90
av8tor1977
av8tor1977's Avatar
Congratulations! What size is the engine?
AV8TOR
Old 04-20-2015, 09:32 AM
  #91
jef-lemmens
AV8TOR
Thanks , bore 25 mm ( 63/64") stroke 28 mm (1"3/32) displacement 13,75 cc (0,84 cu in)
Greetings Jef
Old 04-20-2015, 10:28 AM
  #92
karolh
I can just imagine your level of excitement and satisfaction in hearing your creation come to life, and listening the the video it sure sounds like a sweet runner. My heartiest congratulations on a super achievement.
Karol
Old 04-20-2015, 01:07 PM
  #93
The Ghost
The Ghost's Avatar
Congratulations Awesome Work
Cheers
Old 04-20-2015, 04:45 PM
  #94
av8tor1977
av8tor1977's Avatar
Greetings Jef
Wow, it looks much bigger in the video than 13cc. That makes your work even more incredible though, due to the small size of the parts.
AV8TOR
Old 04-23-2015, 04:25 AM
  #95
Chophop
You mean why make an engine and loose you plane when it quits on you when you can save work ?
I think it's best to start with a utility engine and improve it. Even redesign things like a lighter crank case.
Old 04-23-2015, 06:04 AM
  #96
Cyberwolf
Cyberwolf's Avatar
Well I don't think that assessment is a fact, Myself and several others have been flying home built engine's for years and so far I have never had one quit on me and certainly have never lost a plane due to an engine failure.
Old 04-23-2015, 06:06 AM
  #97
av8tor1977
av8tor1977's Avatar
Well, I do a lot of work converting "utility" engines, and it is fun and rewarding. But the expertise that went into this engine the OP made is just great. It's not made to "set the world on fire" with a special new engine, it is an exercise in machining skill and accomplishment.
AV8TOR
Old 04-23-2015, 06:09 AM
  #98
av8tor1977
av8tor1977's Avatar
The closest I came to that is when I ran my Giant Stik out of gas. I thought I had the field made, but didn't quite make it over the power lines. It hit, and nose dived into the ground, destroying the fuselage clear back to the wing. But I love that plane so I re-built it and you can't tell it ever crashed. It has some grooves in the landing gear from where it hit the wires. I left them there as "battle scars"...
AV8T0R
Old 04-23-2015, 07:09 AM
  #99
karolh
AV8TOR
Ditto to the last two sentences in the above.
Karol
Old 07-05-2015, 12:21 AM
  #100
jef-lemmens
I still had to make the exhaust , finally this is done .
On the picture you see at the bottem the "flat pattern" , right the "folding mold" , middle the "folded part" and on the left the "flange"
Greetins Jef
ID:	2107535   Click image for larger version
