3W finally running!
My Feedback: (34)
3W finally running!
Received my 3W 50 cc back from repairs and it actually makes a loud sound and, get this.....it continues to run! But I do have a question or two for you engine experts....by leaning out the high end, I get 6850 RPM swinging a 22/8 wood prop - is that too much, not enough or just about right concerning RPM's?
Second question has to do with the idle - at idle there is gas dripping out from the carb, I've leaned that out also, but it still is dripping - comments?
Thanks for the time and advise....
Jerry
Jerry
RE: 3W finally running!
Tune it right. Then If at idle gas is dripping, the carb must be hung or sloping downwards, and you probably can't do much about it, except for mounting an air filter.
If the carb keeps dripping fuel when the engine is stopped, the carb needs a checkup.
