fuel tank hookup?
My Feedback: (81)
fuel tank hookup?
I am finally getting back to getting my Monocoupe ready after a 2 year hiatus. This is my first gas engine and I am clueless. Do I just go with the standard 2 line hookup with the t fitting for filling up?. I remember reading about looping your gas lines for some reason but forget. Also does the tank height matter for gas engines? The engine is a Kalt kg22 which is an early G23 if that matters. Thanks for any help
KS
RE: fuel tank hookup?
I use the 3 line method. 1 line to carb, 1 line that I lope on the top of the tank and is a vent line that dangles out bottom of cowel and one is a fill line. Tanks height doesn't make a difference.
I too use the three line tanks. Use Tygon or black neoprene lines. I put a sintered brass clunk on the carb line and a regular clunk on the fill line inside the tank. The sintered clunk cuts down on air bubbles in the carb line.Outside the tank the fill line goes to a fuel dot and the carb line gets an in-line filter. The vent line is the one you can loop on top of the tank before going down to the bottom of the firewall/cowl. The loop prevents gravity from siphoning fuel out of the overflow line as the plane is moved around.
Also make sure you use the proper rubber stopper *safe for gasoline)for the fuel tank.
I too use a 3 line system and for the clunk I use a felt filtered clunk similar to what a weed wacker uses which eliminates both bubbles and debris getting to the carb.
ORIGINAL: dasquirrelisme
Strongly recommend that you use one of the newer tanks on the market that don't use stoppers. The Dubro stoppers for gasoline are undersized and tend to leak (personal experience).
many of usmake our own tanks from Fiji or similar water bottles. You can get fittings from various sources, and I am one of those sources. I also sell the best fuel line for gasoline. OR, if you don't want to mess with making your own, I can build one for you. If interested, contact me directly at my address below
Gas engines are extremely frugal in their fuel consumption and for your 22cc engine (very similar to my G23) a 12 oz tank will easily give you 20 min. of run time and then some.
