DLE 55 electric starter
Old 05-14-2013, 05:26 PM
Todd D
My Feedback: (51)
Todd D's Avatar
Default RE: DLE 55 electric starter
understood, thanks
Old 05-14-2013, 05:36 PM
rcguy59
My Feedback: (8)
rcguy59's Avatar
Here's mine.
www.youtube.com/watch
Old 05-14-2013, 09:39 PM
av8tor1977
av8tor1977's Avatar
That's just really cool.
Old 05-27-2013, 05:59 AM
sbrackets
sbrackets's Avatar
Hello All
This electric start really looks cool and the price isn't bad either. I'm going to be starting my giant TF P-47 build soon with a DLE 55RA and would like to add the ES to my plane. Is anyone on this thread using the ES with a DLE-55RA to know if it will work?
One of our club members just showed up at our field this past Saturday with one of these Electric starts on his Aeroworks Pitts with a DLE-55 side exhause and it worked like a champ. It was very impressive, All the fellows gathered around to watch it uncluding me
I will try to get some video soon of his plane and will add the video clip to this thread for you all.
No more hand flopping a prop in the HOT SUMMER SUN for me. he,he,he.
Old 05-29-2013, 07:09 AM
sbrackets
sbrackets's Avatar
Hey Guys
My buddy came out to the field on Monday to show of his Areoworks Pitts again with the Electric Start. I was able to ask some questions about the Start system and get some pics and video.
He told me that it's got some good safety built into it. Said the when you engage the starter it will only turn oner three times and stop. This is to prevent overheating of the ESC, and start motor.
The only item that needed attention was the magnet pick up for the ei. he had to open the slotted part of the mount to where it would slid back away from the prop hub 1/32" of a inch. He was afraid that the pickup was to close.
trouble loading video without Youtube, so let me edit it and put it up on YT and you'll see it later today.
Oh yeah! one more thing that I might add. The large gears only spin when the engine is starting. Once the engine is started the only part that is turning is the one way bearing on the engine shaft that comes with the kit.
Here is the video clip: http://www.youtube.com/watch?v=wwaDWdQh3xw
Enjoy Jim
ID:	1886757   Click image for larger version
ID:	1886758   Click image for larger version
ID:	1886759   Click image for larger version
ID:	1886760   Click image for larger version
Old 06-26-2013, 10:40 AM
  #31
jwrich
My Feedback: (17)
jwrich's Avatar
I also have the new DLE 35 RA, I wonder if it would fit on it. I plan to install it on a Balsa USA SPAD XIII and I will need the extra weight. I do plan on ordering one of these units for my 55, it will go on a 1/4 scale Mister Mulligan.
Rich
Old 06-28-2013, 07:23 AM
  #32
emengines
Note gear backlash, the gear must add oil!!
Old 06-29-2013, 06:42 AM
  #33
jwrich
My Feedback: (17)
jwrich's Avatar
What type oil would you use? A light machine oil maybe or grease? Thanks for the information. Another question, what is the voltage and type of battery is use with this starter system. Also will it fit on the DLE 35?
Rich
Old 10-15-2013, 03:36 PM
  #34
dasintex
My Feedback: (10)
dasintex's Avatar
I know you need a 1800 to 2500 MaH 3S Lipo, but how high of a Continuous Discharge: 10C, 30C, 60C ? And what about a Burst Discharge Amount?
Old 10-15-2013, 04:51 PM
  #35
RAMFlyer
My Feedback: (65)
A dimension question: What is the distance from center of the prop hub on the DLE 55 to the outside of the starter? Want to see if I can fit one in the cowl of a SkyShark P40!!
Old 10-15-2013, 06:51 PM
  #36
radfordc
My Feedback: (14)
radfordc's Avatar
Originally Posted by av8tor1977
I am afraid that two things would likely happen. One, since nearly all WW2 warbirds were taildraggers with the exception of the P-39, that when trying to run up the engine just against wheel brakes the airplane would just nose over and destroy an expensive prop. If that didn't happen, the wheels would almost certainly just slide when high power was supplied.
I've watched Corsairs, P-51's, etc do runups at airshows. They limit the power to a level that doesn't cause the problems listed above. Why would it be different for a scale model with the same CG and gear geometry? You certainly wouldn't be able to do a full power runup.
Now, if you have a Spitfire and want to do a scale runup, you will need a scale mechanic riding on the tail while you do it.
http://trove.nla.gov.au/ndp/del/article/1111081
Old 10-18-2013, 04:04 PM
  #37
RAMFlyer
My Feedback: (65)
Ok Guys, I can't get MileHighRC to answer their emails so, ONCE AGAIN, I'll ask: Does anyone have the measurement from the centerline of the engine crankshaft to the outside of the starter motor on this electric starter???? I would like to use it on a DLE55 on a SkyShark P40 but want it to fit within the cowl. Everything I have seen this starter used on has had a round cowl (P47; Pitts)...
Old 10-18-2013, 05:26 PM
  #38
airbornrc
My Feedback: (9)
Why do you need to run the engine up to high power levels? Warm it at a high idle and go fly. Run it up first start of the day to make sure everything is ok. I know I will catch a bunch of flak for that but a properly tuned motor should be good to go with no run up.
Mark
Old 10-18-2013, 07:51 PM
  #39
jwrich
My Feedback: (17)
jwrich's Avatar
Sorry Ramflyer, I didn't answer sooner, it is late here . I will measure it tomorrow morning. I have one mounted on a Mr. Mulligan. It does not extend more than 3/4 inch the muffler. Ram
Rich
Old 10-20-2013, 08:12 AM
  #40
jwrich
My Feedback: (17)
jwrich's Avatar
Ramflyer . I measured from the center of the engine to the outside of the starter motor, 3 /18" Here are some pictures. As you can see the starter motor is less than the muffler and no higher than engine stand off mounts. I bought mine from Mile high RC. I did have problems, first bad controller, they sent new one, then the starter motor just stopped working, they sent another one. All in all, Mike from Mile High was very helpful and made his products good. Mile High is another good company to buy from, I trust them and Mike was great. This should fit inside the cowl of your P-40.
Rich
Old 10-20-2013, 09:24 AM
  #41
RAMFlyer
My Feedback: (65)
Thanks jwrich! Mike from Mile High got back to me too and your two measurements are within 1/4 of each other and will allow me to check fit. Now all I have to do is dig out the SkyShark P40 cowl and check. Looks like it should fit... Mike seems to be a standup guy going by your comments, so Mile High is who I'll do business with!
Old 01-29-2014, 01:54 PM
  #42
Mpizpilot
My Feedback: (45)
Just picked one of these for my EME 55. Question, it comes with 4 stand offs. I'm assuming for different motors? Haven't had a chance to really play with it yet.
Old 03-09-2014, 05:59 AM
  #43
Todd D
My Feedback: (51)
Todd D's Avatar
OK, I'm back to considering putting one of these on my TF P47, cool factor is just to tempting. Has anyone put a wattmeter in line with the starter to get the actual amp draw when it's being operated? I'd be interested in knowing that.
Old 03-09-2014, 10:03 AM
  #44
rcguy59
My Feedback: (8)
rcguy59's Avatar
Mine pulls 35 Amps. The earlier version pulled about 19 amps. the motor was updated to be able to start the 60cc engine and the draw went way up. I use a brushed ESC.
Old 03-09-2014, 10:04 AM
  #45
dasintex
My Feedback: (10)
dasintex's Avatar
What Size Battery are using?
Old 03-09-2014, 10:14 AM
  #46
rcguy59
My Feedback: (8)
rcguy59's Avatar
1800 mah, 3 cell, 30c LiPo.
Old 10-20-2014, 02:05 PM
  #47
Shaun Evans
Shaun Evans's Avatar
Mike,
How on earth did you get the first nut off? I've been wrenching away and can't get it off. I used a wrench like you did on the prop bolts and bent them all.....
Old 01-01-2015, 10:44 AM
  #48
g_boxwood
g_boxwood's Avatar
Hi guys,
I got an EME 30-35 auto start kit and this thread will surely help me with the assembly. One question though: I saw in the attached .pdf that there are two keys, the original and the so-called new one? Where did you get the new one? Did it come with the starter kit?
Thank you,
Giacomo
Old 01-01-2015, 04:01 PM
  #49
jwrich
My Feedback: (17)
jwrich's Avatar
On the 30-35 starter kit you the same key that is on the engine. I put a starter on my DLE-30, works fine
Rich
Old 07-25-2017, 03:21 PM
  #50
billy31
Red face electric starter controller.
Originally Posted by irocbsa
For those inquiring about the weight of the system, the starter, battery (3S 1700 mAh), and relay added 1.1lbs to the nose of my ESM Fw-190. That allowed me to remove all of my ballast so it was a net weight gain of about 1 oz in the nose.
If you don't want to pay $30 for that controller, it's easy to rig up a system using a switch and an SPDT relay that will cost you all of $5. That's what I did since when I bought mine they had not release the controller yet.
Cheers to the OP for the nice write up!
hi, can you post a wiring diagram of your controller relay for the electric starter and where i can buy that relay.Thanks!!!!!!
