EVO10GX MODS
EVO10GX MODS
I started this topic to focus the discussion aboutEvgeny-arm's mods with the carburetor of the Evo10GX engine.
Evgeny-arm's original posts and discussion at:http://www.rcuniverse.com/forum/m_11...57/key_/tm.htm
RE: EVO10GX MODS
Result: lower idle, better response between throttle positions. Better mixing between highthrottleand idle.
[youtube]http://www.youtube.com/watch?v=uWgLwP0cNek[/youtube]
RE: EVO10GX MODS
What about dimensions?
How do you fix the idle needle to the body (left image)?
What is the tolerance (difference between hole and needle diamenter) between the hole and the needle H7?
I see you did technical drawings (blueprints) of the components, do you have a photo of the drawings?
NJ
RE: EVO10GX MODS
Always the walbro option,no tweeking,crappy muffler,timing set to[runs good}slaped together,other mods look great though http://www.youtube.com/watch?v=jT7Ct...yer_detailpage
RE: EVO10GX MODS
I will try to do a draw of what I understand from your text and photos.
Я постараюсь сделать ничью, что я понял из вашего текста и фотографий.
I do not have your experience. But I know some of the mechanical theory, and I hope to learn with you.
У меня нет вашего опыта. Но я знаю, некоторые механические теории, и я надеюсь, учиться вместе с вами.
Why not just add a needle inside the original "cap needle"?
Почему бы просто не добавить иглу в оригинальной "шапка иглы"?
RE: EVO10GX MODS
so much talk on this engine why cant to maker see all this and fix the engine iwant a engine to run good when i buy it not have to repair it as soon as i get it think ill call the company and see what they tell me
RE: EVO10GX MODS
I believe along with the majority of users that the engine runs fine as-is . Biggest complaint is the muffler. You can't please everyone and some won't like it because(insert personal reason here). Others (like in this post) will want to try and improve it to satisfy themselves. Great, but I and others would like to see some videos of the engine running with the mods to see what all the hoopla is about.
RE: EVO10GX MODS
The engine runs well for me.
I don't even know that the carb design in fact fuel dumps as suggested and am somewhat doubtful that fuel collects in the idle bar. Even if it does and is a problem, a fix is simpler than making new carb parts.
IL
RE: EVO10GX MODS
oneaew,
What Evgeny is doing is tweaking the carburetor for what he wants. When we have run these engines here for testing and after testing, we haven't had a problem maintaining an idle around 2000 RPMs. This all depends on your idle screw setting, but should be obtainable. Evgeny is more particular about this and prefers to tweak it to his feeling.
We are of course monitoring the situation and continue to perform testing to ensure that we bring the highest quality product to market. All of the comments (good and bad) are noted.
RE: EVO10GX MODS
I've noted the positive statements about the engine but have also noted that some have concluded the engine has problems simply based on the rhetoric about needs for modifications. Once again, I applaud the efforts to refine the design towards perfection, but suggest that most sport/scale users do not require perfection.
I've previously outlined that my engine has suffered no dying problems, in fact quite the contrary... it is more resilient to keep running when compared to glow engines. It has been months now since I tached the idle RPM's and I don't recall what the number was, but can say without hesitation that the idle is sufficiently slow that the model does not roll at idle and slows very well during landings and does not die when landing. Again, my success may be due to the APC 14x4 prop.
As to a simpler fix for the possible fuel dumping, simply plug the end of the spray bar with a brass rod and solder or insert a dob of JB weld. There could be many variables in place such as comparing a fast against a slower throttle servo. Maybe my throttle servo is simply too slow to cause the effect that a faster servo might?
edit note: I'm not an expert on carburation. When I suggested an easier fix would be to close the end of the spray bar if fuel dumping when closing the throttle was an issue, I might have overlooked that the idle bar might in fact serve a secondary positive effect beyond the idle metering. It is possible that fuel does collect in it and then serves as an acceleration reserve when the throttle is opened quickly, thus helping to avoid spool up stumble and a required too rich of idle setting.
If that is the case, Evgeny's design does not provide for such. I simply say... I don't know if the idle bar is intentionally designed to provide the spool up dump or even if fuel collects in the idle bar. I'm back tracking my words however and wouldn't close the spray bar end off without an expert suggesting it is ok.
There are several engine experts among modelers and perhaps some will weigh in on the question.
RE: EVO10GX MODS
Evgeny.. I would never suggest that you are not knowledgeable. I understand that you have space constraints where you fly and when I compare my first landings with my 10GX powered plane with a 11x6 prop screw to those now with the 14x4 there is great contrast and the plane lands much slower.
Above I provided an edit to my previous post saying that I don't know if fuel collects in the idle bar and that if it in fact serves a positive purpose during spool up as a static accelerator pump. If so, my suggestion to close off the spray bar would be poor advice.
I simply do not know.
edit... sport flyers are generally more interested in flying than refining an engine. They wish for general reliability out of the box where their focus can be on the flying.
RE: EVO10GX MODS
I'll take some pics with a tachometer this weekend and post a video as well.
I'm honestly not sure where mine is at rpm-wise with a 12x6 but I know a couple things...Its possible its over 2500... we'll know for sure soon enough.
Idle is below stall speed... meaning the engine isn't getting in the way of slowing down.
It won't quit on transitions.
ORIGINAL: Evgeny-arm
I'll have repeatedly expressed their congratulations.
If you have a solution (except the call to the dealer) - please show.
I really want to see how your engine is operating from 2100 rpm.
I put the emphasis not more than 2100 ....
Easy care in maximum mode.
And most importantly does not stop when you abruptly close the Throttle.
ORIGINAL: AA5BY
a fix is
a fix is
RE: EVO10GX MODS
ORIGINAL: jspauld2
oneaew,
oneaew,
RE: EVO10GX MODS
Evgeny as I mentioned on other threads repeatedly there is only one flaw in NGH carb. LSN profile cant restrict enough at low throttling zone and it gets overrich due to pump pressure (because there is so high suction on fuel line from crankcase).
If you play only with LSN profile to gain better restriction down from half open barrel then you will have a great running engine.
Another solution is,to remove completely regulation system from pump and leave it only as a pump unit.Put a "return to tank line" using a T conn. at carb inlet nipple.Then having a great running engine.
My observation shows NGH 9 engine has excess suction at low throttle zone resulting regulator to open for excess fuel to carb and LSN is the reason of all.If you can make a perfect LSN profile to restrict suction enough then regulator will not get fake signals to stay open for excess fuel which is the reason of erratic running.
RE: EVO10GX MODS
has anyone thought of returning this engine and getting there money back i see more bad then good for this engine does the company see all the things people write about it
RE: EVO10GX MODS
I do not get why would you get to this conclusion.
I read no one saying the engine is no good, by the contrary. I folowed the original topic since the first post and there is no one complaining about it in such way that would justify returning the engine. People only say that the engine is good, I say the engine is good! and I am having a LOT of problems with the original muffler, but the engine is perfectly nice.
I do not want another engine and would buy another one with no doubt! It works as advertized and is as easy to use as any glow. And it pays itself if compared to a glow engine due to the lower consuption and fuel price.
THIS TOPIC IS ABOUT MODS AND TWEAKS and not complains of the engine.
Do not mix things.
I love this engine but I also like to tweak things to have specific performance improvements.
Do not mix things.
