Supertigre missing ignition module
Old 06-03-2013, 09:10 AM
jetjockyf18
My Feedback: (23)
Default Supertigre missing ignition module
Acquired a plane with a ST engine...a 2300, I believe. Have not taken it out yet. It was converted to CH Ignition back late 80's. Owner did not have the ignition module. Can I buy a generic module to replace? This spark plug is much smaller. Help! What are my choices if I want to use this engine?
JJ
ID:	1888550   Click image for larger version
Old 06-03-2013, 10:13 AM
All Day Dan
All Day Dan's Avatar
Default RE: Supertigre missing ignition module
Send Adrian an email. Dan.
http://ch-ignitions.com/
Old 06-03-2013, 01:48 PM
JohnMcGowan
My Feedback: (15)
edit/ I see that you have a gas carb on it
Old 06-03-2013, 02:20 PM
pe reivers
Rcexl has 1/8" spark plugs and ignitions to match.
Old 06-03-2013, 09:25 PM
bcchi
ORIGINAL: pe reivers
Rcexl has 1/8'' spark plugs and ignitions to match.
I believe it would have a 1/4x32 spark plug.
BCCHI
Old 06-03-2013, 09:36 PM
tkg
Bill
I used to chuckle when you said that once you converted an engine, you had to babysit it for life. Guess you were right.
Old 06-04-2013, 12:31 AM
KenLambert
My Feedback: (107)
KenLambert's Avatar
and some need the sitting before the conversion
Old 06-04-2013, 05:24 AM
pe reivers
ORIGINAL: bcchi
BCCHI
Yes they have. My typing error.
Old 06-04-2013, 06:15 PM
jetjockyf18
My Feedback: (23)
Thanks all. I took the engine out of the plane, and it is actually a ST 3000 with a Walbro Carb and what looks like a 1/4 inch thread spark plug. The aluminum prop drive disk magnet actually bumps the sensor when you turn around by hand after I took the prop off. Not sure why. Is that a problem?
Have not checked on a new ignition unit yet. With this type conversion, can I use my regular 40:1 gas oil mixture as fuel? Any other advice to be aware of?
Thanks guys,
JJ
ID:	1888937   Click image for larger version
ID:	1888938   Click image for larger version
Old 06-04-2013, 06:35 PM
w8ye
My Feedback: (16)
w8ye's Avatar
The sensor needs to be moved back so the magnet doesn't hit it.
Without needle bearings on the rod you are going to need to run 20:1 oil.
Old 06-04-2013, 07:55 PM
bcchi
ORIGINAL: w8ye
At least 20x1 10x1 would be better
BCCHI
Old 06-04-2013, 07:59 PM
bcchi
ORIGINAL: KenLambert
And I still baby setting some of them at our field.
I still have some ST parts I need to sent to you. Do you want them?
Still same address.
BCCHI
You can not no how little I really care.
BCCHI
Old 06-04-2013, 08:03 PM
bcchi
ORIGINAL: jetjockyf18
JJ
Does your ST engine have Throttle coupled timing control?.Does the timing wheel move when you open the throttle.Most all of the RCEXL ignitions have electronic timing. These will work with your engine but you would have to lock the timing plate and remove linkage to throttle.
Adrian at C&H can build you a ignition with out electric timing control.
BCCHI
Old 06-05-2013, 03:50 AM
jetjockyf18
My Feedback: (23)
No it is not throttle coupled. Sensor disk does not move.
JJ
