Brison engines 3.2
TN
RE: Brison engines 3.2
Thx for the feedback. I continue to find information on the oil ratio to be confusing. The latest FAQ from the Revolution/Brison web site recommends 80:1 for synthetic oils. Based on recent recommendations from Desert Aircraft Technical staff, I've switched to Redline two-stroke racing oil (synthetic) at a 40:1 ratio for my DA engines. I've just started using my Brison 3.2 engine after several years on the shelf - it runs great! - and I'm tempted to use Redline at the same ratio (40:1) recommended by DA. Any thoughts? Ben
I don't know what the best oil is as I haven't tried them all . Of the oils that i have tried I feel that Stihl , Stihl ultra and Pennzoil Air cooled are my favorites at this time . I used Amzoil Saber for years but changed to Stihl and noticed that my engines run cooler and are better lubricated.
#31
My Feedback: (90)
+1 wouldn't use Amsoil in model airplane engines.
Cool power can be bought direct from Morgan in gallon which makes it about the best buy and protection for the money. http://morganfuel.com/
#44
The concern that I would have with a fully sealed bearing on the rear bearing would be is the seal resistant to fuel/oil/etc.. If the seal breaks down the lube will escape but the lube in the fuel may not readily penetrate the seal enough to provide sufficient lube to the bearing.
