Tillotson carb issue
My Feedback: (15)
TX
I have a 4.2 Sachs that has a HS model Tillotson carb. The carb will not lean out and run full speed if the low end needle is open at all. Seems to run real rich and sluggish transition. If you lean the high end to full rpm, then there is no low to high transition. The high end is only 1/2 turn out to achieve full rpm. I rebuilt the carb with a kit, and the same thing. No difference. Did I overlook something? I know about the critical pump lever setting. Thanks, Paul
