Rebuilding Walbro SDC-80-1
I am trying to get a very old Brison 5.8 running. It is in great shape other than it has been sitting for several years. As I was replacing all of the fuel lines, I noticed that there was a lot of reddish gunk inside the fuel inlet of the Walbro SDC-80-1 carburetor. This led me to believe that I should overhaul the carb. In another post, the recommended kit for the overhaul is the K10-SDC - repair kit; however, after looking at the Walbro parts and service listings, the kit that I need is the D10-SDC - gasket/diaphragm kit.
I would appreciate any advice you might have. Do I need K10 or D10 or both?
Thanks in advance.
Charles
Thanks in advance.
Charles
The D kit contains only gaskets and diaphrams. The K contains those as well as all the other parts including screen, inlet needle, springs, etc. Get the K kit and do the complete overhaul and replace all you can.
Thanks for the advice. I'll report back when it gets here.
Charles
