Voltage regulator question
I am running a DLE20 gas engine. I want to use a 7.4v lipo battery for the ignition that has to be 6.0 volts or less. I have an Align in line step down voltage reg. that is rated at 5.1v that I was using in my heli. This in line regulator was used to reduce voltage in the tail servo. Can I use this same regulator for the DLE20 ignition. Thanks.
Not sure of the input voltage or the max current. I wanted to use it because of its small/light size. I don't want to chance it so I think I will abandon the idea. Thanks for the input.
An RCEXL ignition draws around 600 milliamps at high rpms. So if your voltage regulator is rated at 1 amp or more, you have more than sufficient current handling capability to run your ignition with a safe reserve. The old original ignition on the Zenoah engines is a different animal. It draws much more current.
AV8TOR
AV8TOR
Why not consider running a single battery in your 20cc setup with a Tech-Aero IBEC that provides the a choice of voltage outputs and gives you the extra security of having ignition kill from the radio.
Tech-Aero Designs LLC
Pete
Pete
Pete
Pete
Just did a quick search. Is this what you want to use?
http://www.hangar-9.com/Products/Sup...dID=AGNK10381A
If so it appears to take 6v in and regulate it to 5.1v out. Looks like its used in conjunction with the Align RCE-B6X regulator that takes a 7.4v lipo in and regulates it to 5.8v out.
Without any real specs on that unit I wouldn't risk it. Just get a BEC (Battery Eliminator Circuit) similar to the one listed above. They are used in electric set-ups so you have a constant regulated power source to the receiver. It's in essence a regulator that can a handle high voltage input,
My Feedback: (19)
The Align step down is no more than a single diode in series with the power lead. Not a regulator at all. The forward biased diode just drops the voltage the standard amount that most any diode does.
I recommend a good IBEC such at the Tech Aero unit ... the same as several others have recommended.
Pete
Pete
I've been using the Tech-Aero plugged directly into the Rx for a few years. Works great and not one problem.
if this is what you want to use then yes you can http://www.ebay.co.uk/itm/like/27126...ff14=95&ff19=0
The OP stated he only has the dongle part or just wanted to use the dongle. Apparently that is only a single diode wrapped up in shrikwrap. He could connect it to the 7.4 lipo but it would still be providing close to or over 7 volts to the ignition.depending on the battery charge.
