Evolution 62 EFI
My Feedback: (19)
There is a world of difference between mechanical Fuel Injection like the ME 109 had and Electronic Fuel Injection.
Mechanical injection does not have the need of an O2 sensor, Manifold Absolute Pressure sensor, Throttle position Sensor, Electronic Control Unit and so on.
While Mechanical is just that it utilizes a high pressure pump and injectors set to pop at a certain time and pressure
Granted the electronic is far more fuel efficient but we all got by with the Mechanical for years and years.
Anyway back to the engine at hand here, W/O and O2 sensor or ECU I can't see how it can operate properly. The early Holley Projection unit's didn't have an O2 sensor and the ECU got lost constantly it was a Major PITA to deal with.
I'll let someone else try this out for now and see how well it does work, Besides I like to tune my engine's myself anyway.
WI
As I said before this does not appear to be true fuel injection but more like a smart carburetor, probably could not
be called true throttle body injection either, but still could work very well, you can map throttle position, RPM to give load the
numbers and use a look-up table to deliver the correct air/fuel ratio for the given load point.
With this type of system you don't get all the compensation for other atmospheric variables, some chain saws have used
similar systems.
similar systems.
ID
Evgeny-arm
I don't know what or who you think you are but I am not one bit lazy and resent your statement. I did look at the Mega Squirt System it means absolutely nothing to me or this thread.
Truckracer I knew of some other types of mechanical FI but thought that most were way outdated and no longer in use, but not so. Here is a link I found to a modern day Mechanical Fuel Injection unit for a plane.
http://www.eci.aero/exp/fis_operatingmanualM242.pdfTruckracer I knew of some other types of mechanical FI but thought that most were way outdated and no longer in use, but not so. Here is a link I found to a modern day Mechanical Fuel Injection unit for a plane.
As far as the mechanical for race cars go,
Here is a good read on constant fuel flow injection used in top fuel cars.
http://www.competitionplus.com/12_17_2003/fuel_101.html
#31
My Feedback: (19)
Evgeny-arm
http://www.competitionplus.com/12_17_2003/fuel_101.htmlHere is a good read on constant fuel flow injection used in top fuel cars.
Back on target, it will be interesting so see how well the Evolution system works and how it evolves in the future.
#32
1 Post
It does not need an O2 sensor for several reasons:
-the engine design parameter is not hinged on stiochiometric AFR. That is a requirementonly to allow emissions controls devices to function as calibrated. It is NOT a necessary function for this system.
- O2 sensors cannot handle high percentage of contaminant in the fuel. It will plug up and fail ver quickly with 2stroke oil in the mix.
- An engine's ECU can determine load, and fuel demand by monitoring throttle position against rpm to determine load. Couple to a mass flow sensor (air intake sensor as described by HH) the ECI algorithm will determine correct fuel metering and can be designed to erroe correct and either slightly overfuel or underfuel (non prefered).
This engine is not flying long duration missions carrying relatively heavy payloads to the airframe. It is a toy airplane engine designed to take tuning out of the hands of Joe Soap.
Lastly, comparison with methanol fuel injection is comparing apples and oranges. Methanol fueled engines have high oil percentage and the oil presents problems to fuel metering
#33
OH
Sometimes we do not understand each others languages enough and this causes us to make false judgements.
Personally, I love interacting with people from other countries. Many times I have found very useful and innovative information from them.
#34
OH
Do not worry for my income and my taxes.
I can afford it.
Or do you think that we are savages and walk arm in arm with the bears that have no right to of my view?
do not even know how to rate your message - an insult or an excess of self-conceit of himself.
Have you any phases its permanent propulsion capable calculate?
Cyclic or calculate its permanent propulsion cylinder filling?
I'm afraid you're even in your life, not one pistons your engine did not.
But allowed to evaluate someone on territorial jurisdiction.
Your remark - this rudeness.
I can afford it.
#35
MN
The converted nitro-to-gas China brand Evolution= good track record
I would guess that this will be no different....
Why the heck would one release something that didn't work??
I doubt horizon would want to go through this again. (1st version gas saitos had carb issues)
I think you will be surprised at how well it works....
#36
My Feedback: (19)
As for companies releasing products that either don't work or don't live up to expectations and with no reflection on Horizon, our hobby has been full of bad products over the years. I could list dozens without having to strain my brain very much.
#37
ID
#38
To get best millage, and save the world :-) The engine will run just fine even though the mixture is a little off.
Try disconnect it from your car. You will get an engine management light, and you will probably be able to feel that it runs slightly diffrent.....but not much
But I garantee thay you millage will drop :-)
#39
An oxygen sensor is definitely NOT needed for the operation of a fuel injection system. An O2 sensor is a trim device. Once the engine is warmed up, the system goes into what we call "closed loop" and that is when the O2 sensor goes to work. It makes very fine, (and fast) tuning adjustments to maintain an exact fuel/air ratio to optimize emissions, (smog), and fuel mileage. When you floor the accelerator, the engine drops out of "closed loop", and the O2 sensor is not used. Then the computer in the FI system reverts to a map of how much fuel it should be allowing into the engine. This map is also used to run the engine during a cold start, as the O2 sensor cannot work until thoroughly warmed up. As for practical use, you could disconnect the O2 sensor, and you virtually could not tell a difference in how the engine ran. It would just get somewhat reduced fuel mileage.
Also, a Mass Airflow Sensor is not needed for fuel injection. Fuel injections systems without a Mass Airflow Sensor rely on a MAP sensor, (Manifold Absolute Pressure), to supply needed info on engine operation in order to supply the correct amount of fuel to the engine.
And lastly, high fuel pressure is not needed. A port fuel injection uses high pressure, usually somewhere around 40 psi +/-. But throttle body fuel injection only needs 9 to 12 psi for most systems.
Having said all that, I think this new system is cool, and hope it filters down into the hands of us poor boys someday soon! No engine is harder to supply with a perfect fuel mix than a two stroke, and fuel injection would be great to have. Especially if it were user tunable.
AV8TOR
AV8TOR
#40
{ Also, a Mass Airflow Sensor is not needed for fuel injection. Fuel injections systems without a Mass Airflow Sensor rely on a MAP sensor, (Manifold Absolute Pressure), to supply needed info on engine operation in order to supply the correct amount of fuel to the engine.
AV8TOR[/QUOTE]
But you do require one are the other. You have to have a MAP sensor at the minimum, without one the engine will not run with fuel injection or throttle body. You are right about the O2 sensors, cars run all the time with them disconnected or broke, but a MAF or MAP sensor is
required. And if it requires at least 9-12 psi where in our free flow tanks are we getting that. The engine does not look to have a pump. I think it is neat but not really a need. What is so hard about tuning a 2T engine?
AV8TOR[/QUOTE]
#41
I like tuning two strokes. But I would also welcome the opportunity to play with fuel injection on one. I hope they create a retro-fit model and that it can be easily tuned/programmed with a computer.
I like carburetors, and have no problems with them, but do you think I would take the fuel injection off my Vette and put a carb on it?? No way. Fuel injection is way more efficient and costs nothing in power. If the aftermarket systems weren't so dam expensive, I would take the Holley carb off my 450 horsepower big block Blazer and put fuel injection on it in a heartbeat!
AV8TOR
AV8TOR
#42
1 Post
AV8TOR
AV8TOR
required. And if it requires at least 9-12 psi where in our free flow tanks are we getting that. The engine does not look to have a pump. I think it is neat but not really a need. What is so hard about tuning a 2T engine?[/QUOTE]
9-12psi absolute or gauge. If absolute then those pressures are vacuum since 1atmosphere is about 14psi.
A MAP sensor would be the minimum requirement to obtain a rough volumetric flow. Mass flow would be first prize though
#43
AV8TOR I agree that they would be fun to play with and you are right about fuel injection. I had carbed bikes for years and until I bought my Roadliner I never realized how nice a fuel injection system on a bike could be. I will watch these to see how they do and if the initial
testers find them durable I will try one.
#44
Generally, a throttle position sensor and ignition timing control/sensor are the minimum. Run well? not necessarily.
Remember that current automobile systems often do not have a mechanical throttle valve connected to the accelerator pedal. They rely on "the computer" to set
fuel, timing, and air flow, based upon the pedal position and other measurable operational conditions.
#46
My Feedback: (19)
Hello.
Here's a perfect system -
http://www.ecotrons.com/products/2_s...injection_kit/
http://www.ecotrons.com/products/hon...injection_kit/
The problem with these KIT - they do not take into account the dimensions of the model application.
But I personally do not see this as a big problem.
My hands and my head could easily cope with this.
Read the manual and you'll see that my two questions are not unreasonable.
http://www.ecotrons.com/files/SE-EFI...ion-Manual.pdf
If buying this engine I would not be able to give these KIT.
My opinion is that I threw away money.
I do not need a box filled with compound, which I can not say how to work my engine.
I do not need a box in which I can not ask what is wrong is going on in my engine.
EFI systems are not compatible wretchedness ignition type Rcexl
What then oddball angles scored there, considering that he did it so perfectly for all engines.
That that box can be put for 2 stroke and 4 stroke engines.
The whole world uses it stupidity.
Everyone understands that this is wrong, but no one has yet made a version of this fix.
And if we Evolution offers a system EFI, the same as Rcexl box.
It will not be a step forward.
It will be another experiment for our money.
Good luck to all.
Good luck to all.
For what they cost, I thought they work quite well. Maybe we can look forward to a better quality reasonably priced alternative out of Russia one day?
#47
Evgeny, I think the translating program that you are using is making you sound a bit aggressive, and it is offending poeple a little when you read the english translation :-)
I think we need to see this product in action before you can tell how bad it is, and all the faults it has....because there might be a chance that it actualy works fantastic just as simply designed as it is :-)
#48
My Feedback: (19)
MA
Pete,
Could one use a 2S A123, or Li-Fe battery (6-6.6V), or does it need the whole 7.4V of a 2S Li-Po? As you know, A123's / Li-Fe's have better discharge curves, are much safer, and more user friendly than Li-Po's.
Thank you in advance,
#50
Pete
