Gas Engine Selection for The World Models 1/4 Scale Piper J-3 Cub?
I'm new to gas engines. Recently I purchased a World Models 1/4 scale
Piper J-3 Cub. The manual recommends 0.91 cu. in. displacement for a 2
-stroke engine, or a 1.20-1.60 cu. in. engine for a 4 stroke engine. The flying
weight for this Cub 14-16 lbs.; the wingspan is 104 inches.
I definitely want to buy a gas engine for this plane, but I'm open as to 2-stroke
or 4-stroke. I would also much prefer an engine whose carburetor mounts in
the rear (rather than on the side).
Here are just some of the engines I've been looking at:
Saito FG-21 (4-stroke gas)
OS GT-22 (2-stroke gas)
OS GT-33 (2-stroke gas)
DLE 35RA (2-stroke gas)
Any ideas, suggestions, or recommendations on engine choice would be much appreciated! Thanks.
jim
PS: If you respond to this tread, thanks! Just please .... if you recommend a particular gas engine,
tell me why. Thanks again!!!!
jim
I would go with the DLE 35RA so you do not have to destroy your cowl for the muffler.
Another choice would be a Quadra 35, they are rear exhaust but a little heaver if you do not mind the extra weight for just good sports flying.
Another good choice is the ZP38, rear exhaust and will last forever.
http://www.horizonhobby.com/products...engine-ZENEP38
Milton
Milton
I built a Sig 1/4 scale Cub, full wing (108" I think it is) and have a DLE-20 in it. That is plenty of power for me. In fact if I want to cruise around at a scale speed I'm under 1/4 throttle. I bought the J-Tec Pitts muffler for it and the whole package fit's very nicely under the hood. I'm very happy with it. Now, if you are looking to do 3D, then the DLE-35RA would be the way to go IMHO.
My Feedback: (19)
Just about any of the current crop of 30 or 35 size engines are a perfect match for a 1/4 CUB. Seems like a lot of power to many people, but most of these planes weigh 14 -17 pounds so the power is not excessive. Couple that to something like a 19-6 or 20-6 in the case of the 35 and you can have the best of both worlds ..... throttle back and fly around all day in a very scale like manner or push the throttle forward and climb like there is no tomorrow.
This size engine will fully conceal in the cowl. Of course the rear exhaust DLE 35 has the exhaust in the rear but something like the DLE30 will also conceal the exhaust if a wrap around Pitts muffler is used.
I'm a CUB nut of sorts and my current one flies with a DLE 30 that has a Jtec wrap around Pitts muffler. The muffler easily fits well within the cowl. This plane was also flown with a Saito 180 for many years and then a Syssa 180. I grew to hate the Saito because of the exhaust goo, the expensive fuel and difficult hot starting. The Syssa flew the airplane quite well but I'll just say that engine was an expensive mistake and leave it at that. The DLE30 was easily the best of the bunch. I'm building a new CUB this winter and it will be powered with the DLE35.
An added advantage of this size engine is that it balances the plane quite well w/o extra weight.
Of course, something like the DLE20 would power this size CUB quite well but I hate the beam mounting of these engines (personal preference). It is so much easier to mount the engines on standoffs. So overall my recommendation would be the DLE30 or 35. Of course the OS engines would be excellent alternatives but at a greater cost.
Guys:
Thanks so, so much for all the useful input here! I really appreciate it. Right now I'm
leaning towards the DLE 35RA, mainly because of the price and the power. Since I will
likely be installing this engine on a Goldberg Anniversary Cub with Super Floats,
the extra power provided by the DLE 35RA seems like a good idea.
If any of you think I am off base here, let me know.
Thanks again,
jim
Thanks again,
jim
My Feedback: (19)
Guys:
Thanks again,
jim
Thanks again,
jim
Ground clearance could be a problem on the Goldberg Cub with larger props. Something to consider.
The DLE 35 might be a bit large for the Goldberg Cub as that airplane is quite a bit under 1/4 scale. The 35 will still fit in the cowl though but the DLE20 would fit even better. I had a Valley View 20 in a Great Planes 60 CUB for awhile. That airplane is very similar in size to the Goldberg and I thought it was a good match. It would have had plenty of power for floats.
My Feedback: (19)
My Great Planes 60 CUB balanced with the VV 20 and Pitts muffler. My larger Hanger 9 1/4 CUB balanced with the DLE30 and Pitts muffler. No additional weight was required.
I'll know in a few weeks how my new modified SIG CUB will balance with the DLE35. Right now I don't expect to add any balance weight. To be fair, mine won't have as much detail work as your's has as I built mine to be an everyday, beat the heck out of it sort of airplane. I do like the rib stitching and other detail work on yours, just not for me this time around. I'm sure that detail work and finish added to the tail weight. Very nice CUB by the way! Every RCer needs a CUB, or two, or three ........
IL
Jim Hargett one bit you left out is flying style. Example, I like my Cubs to prop hang once in awhile. It does sound like you are leaning toward an engine that will do that.
From your list would go with the DLE 35.
Thanks again, guys. I'm now pretty sure I will go with the DLE 35.
Cub Flyer Fresco: my apologies: the DLE 35 will go on my World Models 1/4 scale Cub, and NOT on my
Goldberg Anniversary Cub.
As for the Goldberg Cub with floats, that will be powered by an OS 91 Surpass 4 stroke.
Again, thanks for all the useful input here.
Jim
Jim
Dadragon:
Thanks for the suggestion. The RCGF 30cc Twin does indeed look ideal for my World Models 1/4 scale Cub.
Do you know anyone who has actually flown with this engine? It's seems to be new on the market, so I don't
see much in the way of flights, reviews, and so on, on YouTube and here. Thanks.
jim
jim
