How far will a gas engine draw fuel?
Reply
Old 02-22-2014, 04:26 PM
gregandhollie
gregandhollie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How far will a gas engine draw fuel?
I'm working on a CMP P-40 which I've installed an AGM 30 gas engine in. I have a 16 ounce tank about four inches aft of the engine. I'm looking at putting an inline fueling valve about six inches behind the tank, meaning fuel would leave the tank to go back to the valve and then about ten inches forward to get to the engine. Will the carb draw fuel from that far without issues or do I need to rethink my plumbing?
gregandhollie is offline
Old 02-22-2014, 04:33 PM
BadAzzMaxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the pump is working right it will draw 3 feet straight up.
Milton
BadAzzMaxx is offline
Old 02-22-2014, 06:20 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Careful will filling valves, some have a tendency to leak.
speedracerntrixie is online now
Old 02-22-2014, 06:46 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While a Walbro carb can pull fuel quite a ways, I'm not sure it is wise to route fuel lines behind a tank just to route them forward from there to the engine. Just does not pass a reasonableness test in my book. I would try my best to locate the filler somewhere between the tank and engine.
Truckracer is online now
Old 02-22-2014, 06:49 PM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On my test stand (break-in stand) the fuel can is three feet below the engine.
acerc is offline
Old 02-22-2014, 07:46 PM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would suggest keeping the refueling and defueling line separate from the fuel line to the engine. One problem is those fueler thingies can let air leaks develop. Then the next problem is when you are refueling, the pressure of the fuel in the fuel line can overcome the fuel pump and regulator thus damaging the carb valves and or flooding the engine out.
But otherwise as mentioned, if the carb's fuel pump is in good shape, it can draw fuel through up to three feet of fuel line.
earlwb is offline
Old 02-22-2014, 08:05 PM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 for all posts so far.
AV8TOR
av8tor1977 is offline
Old 02-22-2014, 08:24 PM
mikes68charger
My Feedback: (33)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like useing those fuel dots. But I build my fuel tanks with 3 lines setup. Then use the fuel dot on the fill hose with the other side of the dot pluged with a small peace of hose with a bolt in it
This way if they leak no fowl
mikes68charger is offline
Old 02-23-2014, 05:16 AM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I and many have experienced leaking with the fuel valves ...eventually.
A 3-line tank works well using a fuel dot instead of a two line tank with a valve,
flyinwalenda is online now
Old 02-23-2014, 08:05 AM
irocbsa
My Feedback: (12)
irocbsa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 for the three line tank with a fuel dot.
irocbsa is offline
Old 02-23-2014, 04:18 PM
TheRickster
My Feedback: (12)
TheRickster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been using the simple two line with a "T" in the fill line for years from glow up to Gas.. I like the fact that to test the fuel system for proper operation all I have to do is hook up the fuel line and draw the fuel out. It then tests for leaks(Bubbles) and for proper clunk operation...
Rick
TheRickster is offline
Old 02-24-2014, 08:41 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+2!
The three line setup reduces the possible points where air can be drawn into the fuel line to the absolute minimum, and also allows you to use a felt filter clunk effectively, which you cannot do with two line setups.
Pete
pilotpete2 is offline
Old 02-24-2014, 10:57 AM
av8tor1977
av8tor1977's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by pilotpete2 View Post
+2!
Pete
Yes, I agree completely. I used two line setups in the past and didn't have much in the way of problems, but the 3 line setup is definitely better for the reasons just stated. All my planes are now set up with three line systems.
One little tiny air leak in the fuel supply line can ruin your entire day.... and perhaps your airplane!
AV8TOR
Old 02-24-2014, 06:55 PM
Firewalkerd1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is a three line set up? How about a diagram!!!
Firewalkerd1 is offline
Old 02-25-2014, 12:23 AM
3136's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't have a diagram, but it's simple,
1 line goes strait from carb (via brass pipe in gas stopper) into tank with a clunk, I prefer a heavy felt clunk.
1 line goes to a looped vent line, loop 3 times and position at rear top of fuel tank, connection inside tank is a brass tube bent to top of tank
1 line goes directly to a fuel dot for re-fuelling, I bend a tube as per vent line for this so I can see what's happening.
3136 is offline
Contact Us Archive Advertising Cookie Policy
