EME gas engine review
yes I have a 60 from MileHighRC.they have excellent service and parts.EME60 is stronger than a DA60 on a pipe,by just a little.on the stock exhaust it's a even match as far as rpm's go.
the EME is smoother than the DA too.starts good,you can tune out most of the burble,carb response good to needle twisting.i would buy another one.never tried any other EME's.
but for less than a 100.00 you can buy a GP61 that has a ceramic coating on the cylinder.the GP61 will get about 200 more rpm's than the EME.both have good bearings and piston rings.
