Dle 30 ?
NY
Dle 30 ?
Working on a rc guys agwagon and got a dle 30 for it. I was originally gonna use a different motor and the throttle lever would have been on the right side, so I did my elevator servo on the left side of the servo tray. But the throttle lever on the dle will fall on the left side. Rather than changing the elevator set up I was just gonna spin the carb around the other way so the throttle lever is on the opposite side. Can't think of any reason why I can't do this but figured I'd check.
My Feedback: (58)
VA
I just turned mine and turned the reed block also because it was really stuck to the carb. Had to readjust both needles to get it to run. Have not flown it and was wandering if I should have turned the reed block. Thanks for answering my question. Waynem.
