Evolution 10cc gas
Evolution 10cc gas
Hello
I would like to know if somebody can explain the wiring setup for using one 2100 LiFe battery to run both receiver and electronic ignition through opto cutout switch?
Gas engine is in a Calmato.
Would like to keep weight down as much as possible.
Would like to get 4 x 10 minute flights per charge.
dutchy50
dutchy50
Not a good move in my opinion. I would use the opto kill switch for the ignition and a nicad or NmHi battery for the ignition and use the 2100 LiFe battery with a regulator for the flight pack. I have 3 models setup this way and can fly 5 15 minute flights safely then recharge both batteries.
Hi JohnB96041
The engine is new and in the manual it states recommending 2S LiFe battery 13mAh 6.6V, max draw power at full throttle is around 450mAh and more typical average has been between 250-300mAh.
And yes will be running ignition through an Opto kill switch from my transmitter.
dutchy50
dutchy50
Two batteries in a 10cc powered plane is not a practical plan when you consider the space that most models provide for an engine in that displacement.
A good IBEC, such as the Tech-Aero makes more sense. The IBEC weigh just a tad over 1/2oz. and a 2S LiFe at around 1800mAh and is very light.
I run a 2S 1800mAh LiFe in a 4 Star 64, powered with the 15cc Evo. I usually limit myself to 4 flights on a charge, and with the quickly top off the battery at the field, I could fly that model all day if I wanted to.
Pete
Pete
Hello
dutchy50
dutchy50
Regarding flight times from a charge, I have a 20cc powered Revolver hot rod (6 digital servos, 5 of them over 100 oz torque) that is often flown 2 evenings on a charge (6-7 flights?) with plenty of left over capacity. It's using a single 2300mah genuine A123 and no, we're not talking about a plane that is taken up to fly laps. It's generally flown pretty hard....
Hello
I`m a bit confused about the specs that came with this kill switch!
I have the Rcexl Opto gas engine kill switch V2.0, can someone please tell me what is the highest input voltage these things can take? I would like to use a LiFe 6.6v. I am using a Rcexl Evolution 4.8v-8.4v operating voltage electronic ignition.
dutchy50
dutchy50
I run two LiFe packs in the 10cc Meridian (1800 and 2100) and everything is fine. The packs are small in size ;plenty of space ,and they don't weigh much. I'm not a fan of one battery for both .
If there is absolutely no room for a second battery you can run both ignition and receiver off of one battery . Most Lixx receiver packs have two receiver plugs on them so one would plug into a mechanical slide/push-pull switch mounted on the plane and then the output of the switch would plug into the OPTO switch and then the OPTO switch output would plug into the ignition and of course the receiver plug of the OPTO would plug ito a port on the receiver that can be controlled by one of the transmitter switches(on-off).
The other receiver plug of the battery pack would plug to into a second mechanical slide/push-pull switch mounted on the plane and the output of that switch would plug into the BATT port of the receiver.
Limit the first fight to 10min and then come in and recharge the pack and see how many milliamps went back in and then you can calculate how many 10 min flights you can safely get on a charged pack. Don't just measure the voltage as LiFe packs have a flat discharge curve and the voltage will remain constant as the current delivered drops as the pack discharges.
I've ran both with the 10cc, 2 battery pack configurations and 1 pack configurations
For the single pack I used a LiFeSource pack that has two male connectors, connected 1 to switch for receiver and 1 to opto-kill for engine. To date ( ~1yr or so ) I've had 0 issues with that setup. Similarly I've had 0 issues with the dual battery setup as well.
I was significantly more careful with the 1 battery setup though prior to flying... lots of range checks before I had the confidence to fly it.
I've never understood the logic of having two batteries on board and no battery redundancy for the receiver/servos
Two batteries through two switches to the receiver, then the ignition connected to the receiver through an IBEC provides dual battery redundancy without the need for thee batteries. The single receiver and separate ignition battery has the downside that if anything happens to the receiver battery or switch, the engine will continue running at wherever the throttle was set at the time receiver power was lost, as no radio failsafes will be activated in this scenario. With a single battery/IBEC setup, at least you'll crash a little safer. Yeah, I know, that also applies to any glow powered plane, but having the engine quit with a dead receiver is a plus in my book.
Pete
Pete
Pete
Pete
the two battery setup is purely to isolate the ignition and receiver power sources from each other. Its a safety thing and if you have space , probably not a bad idea. If you don't have space/weight to spare though, careful setup of a single battery seems to work ok.
Pete
Pete
Good thought, especially since in many cases not having two open receiver slots open on a receiver results in having to Y into one of the servos. The rudder is certainly a good choice for those who like to fly knife edge, which I like to do... a lot!
Pete
Pete
