Saito FG-60R3
#1051
Baffling
I realized I never posted any pics of the baffling I did on my P-47/Saito FG-60. I ended up making a baffle out of 1/8" lite ply and mounting it to the exhaust ring. I then used craft foam to tighten up the space between the cylinder heads and baffle. I also used it to close up a large gap I had at the bottom of the cowling(not pictured).
#1052
#1054
I flew my P-47 on September 3rd for the first time since I had a cylinder failure back in May. Flew great but I never got above 1/3 throttle after takeoff and the engine temp got up to 371* wayyyyy to hot. I spent that Sunday evening and most of that Monday making a baffle for the engine and tested it that afternoon. Even at full throttle it got up to 330* but cruising around at half it would hover around 300*. It was still too hot but I had't tried all my ideas yet. It was 95* here on that day. I have since did the header wrap. On just the circular part of the exhaust. That brought it down to 277* on an 89* degree day. I see that someone had an exhaust ring failure that broke off the ring off. I may still keep my wrap on a little longer.
I didn't check to see if hot air came out of the cowling or check the sides of the plane behind the cowling to see if it's warm but I will next time I go fly.
MD
MD
#1055
Thanks guys for the thumbs up. I put some thought in to it. I honestly couldn't figure out an easy way to attach the baffle to the cowling. Plus I had been helping my father in law with baffling on his full scale Vans RV6-A. An the baffling is attached to the engine with rubber that seals it to the cowling. So I tried to incorporate that method into my plane.
Md
Md
#1056
You did a nice job on the baffle, but with the Keleo exhaust failures we've heard about, I wonder if the ring is up to the task of holding up the baffle through all the flight vibrations, etc. Hope so!! Again, nice work!
#1060
Has anyone used a gas spinner with the FG60? I have mine in a Top Flite FW190 and it comes with a gas 4 bolt hole spinner, but obviously has no knurling to grip to the prop like a glow spinner, does it work to just nip it up tight? Or is there a method to rough up the gas spinner to grip the prop?
#1061
MD
MD
Dan
#1062
Did you fly with that carb on?
Dan
#1067
Well....finally got a chance to see if my crashed Saito FG60R3 would run with the Teflon thermal insulator tube. Yes, it runs, albeit only on 2 cylinders. I had noted that the ignition wire for No.3 cylinder was damaged, but thought it might still work. It doesn't. No 3 cylinder would not fire at all.
Am sourcing a replacement ignition unit. Hope that fixes it. Doesn't appear to be anything mechanically wrong with No. 3 cylinder.
For those in the Asia/Pacific region (who cant use Horizon) here is a bit of a heads up about RCJapan. I approached them 6 weeks ago for availability and price of some replacement parts. They said they contacted Saito. Nothing doing so I contacted RCJapan again, they said Saito is known for very, very, very slow response to requests about parts.
Well, it's either RCJapan who's the problem or Saito. At this stage it looks like Saito. Last Saito I will ever buy, in my book it is unforgiveable to manufacture and sell goods (especially pricey model engines) and not be willing to support purchasers after market.
#1068
Alfie, my experience with Rcjapan is the same. If it is common parts and things, they normally get it within a few days or a week, and they communicate quite well normally. But, if it is not common stuff, they depend on Saito. Had the same issues with a new gasket set. WRT Teflon tube, I had some issues with the one I made too, so I got a Bakelite one turned down. Works better. I think the Teflon gets softer when temps go up, and may not seal as well. Not saying it's your problem, because mine ran with it, just a little inconsistently.
#1070
#1071
Well see!
#1072
Yep, I wouldn't condem the tube at this point either. If there is any damage to the HT lead then I would look to get that fixed before going anywhere else. Also try swapping a plug and see if maybe one of them isn't duff. As you say, if fuel is getting to one, it should reach all.
#1073
No.1 broke today
Well my FG-60 is now a 2 cylinder instead at a three cylinder. No.1 let go today on my third flight. It was 41*. I guess don't be like me and fly ur FG-60 in cold weather. This is a Goldielocks engine. Not too hot not too cold. Just a nice warm. Will send an email to horizon and see what they want to do. On a good note it stayed together long enough to land and cut it off with the ignition kill switch. So I'm 2 for 2 on landing with a broken cylinder. This one had 3 ears broke off so it was a close one for sure, and oil everywhere. I see small bits of debris in the engine this time and the piston got scuffed pretty bad. So will need to replace that one. I give this to having a good ear and know the engine well enough to know when something is wrong.
#1074
Bummer!
Sorry to hear this news! Did Ray mod your engine? I am wondering if anyone with Ray's modifications is having the cylinder breakage issue. Please let us know if you have...
#1075
My Feedback: (46)
