DLE 85 carb issues
My Feedback: (45)
CO
Truckracer - Thanks for your advice. I got a chance to fly the plane with your recommendation of using a pill bottle on the end of the air intake line. It worked liked a charm. The DLE-85 had all the power as advertised and it flew my PT-19 (25 lbs) with no problems, Still being a brand new DLE-85, I still have to make a few high and low end adjustments, but there was no engine bog down what so ever.
Thanks again!
Keith
Thanks again!
Keith
My Feedback: (19)
Thanks again!
Keith
Thanks again!
Keith
Plenty of power to vertical the old Edge (26 lbs) well past 400 ft! So far I'm a happy camper!
#33
My Feedback: (19)
I've run my DLE 85 on both the DLE clone carb and the Walbro WJ71. They are almost an exact copy of each other and are directly interchangeable. You may have to fashion a throttle arm for the WJ71 but that is normal. Even DA that also uses the WJ71 on the DA 100 and 120 make their own arms for the carb. An easy task. I currently use the DLE carb on my engine as it has a bit better throttle response than the WJ71.
#37
