RCEXEL opo w/BEC
My Feedback: (7)
http://www.tech-aero.net/ultra-ibec
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDVBT&P=ML
The RCEXL is doesn't have a regulator, the IBEC from Tech Aero D. Is a kill switch and has a regulator, have both, both work fine, prefer the AT IBEC.
The advantages as stated in the Tech-Aero website:
ü Eliminates the need for a separate ignition battery and mechanical on/off switch.
ü Compatible with the power requirements of single and multi-cylinder model CDI ignition modules via jumper selectable 5V, 5.3V, 6.1V and 6.6V voltage outputs.
ü Enhanced flexibility and safety via transmitter control of CDI ignition power from a receiver auxiliary channel.
ü Tech-Aero exclusive 4 stage filtering removes interference from CDI ignition noise in the wiring path to the receiver, permitting use with 2.4 GHz Spread Spectrum and 72 MHz FM radio receivers. *
Personally though, I would add an on/off switch on the airplane anyway, and I believe that is an AMA requirement in any case.
AV8TOR
AV8TOR
