Help 3MM 53 prop washer
My Feedback: (30)
Anyone have an idea where I can get a prop washer for a 3MM 53cc engine?
This is the one that has the hole in the center for the shaft and 6 small holes around the outside that the bolts that hold the prop on go through the prop into the back plate.
Any help will be appreciated!
My Feedback: (19)
I have one here but not for sale. You should have no trouble finding a replacement as the 3mm 53 has the same bolt pattern as the very common DA and DLE 85 thru 120 engines plus many more. Here is a link to one at Tower.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDRHF&P=Z
All these prop washers have a 10mm center hole and 5mm prop retainer holes on the same bolt center.
