zdz super 80, need ideas
NY
so, it sat on the shelf awhile. put on a brand new walbro carb, bought new high test gas, mixed 40-1 with penziol. set the needles to 2 turns open and did the 5-5-1 starting .started right up and idles smoothly. however it will not run at high speed. no matter where I put the needles, including falling out open it will not run at high speed,.but it will idle all day with no quiting. if I put the choke 1/2 closed than it will run at full throttle.open the choke, it sounds like it goes lean and dies any ideas ?, I,m at the end of my rope.
My Feedback: (29)
It sounds like the pop off pressure is too high. Under the diaphragm there is a spring loaded fork that controls fuel flow through the carb. If the fork is adjusted too low the pop off pressure is too high and the diaphragm does not have enough movement to pull the metering needle off its seat long enough to get enough fuel through. The fork can be bent outward and this will increase the fuel flow and the needles will become responsive again. Word of caution, this is a very delicate adjustment. .020 of adjustment is fairly large. Adjust too much and the metering needle will not seat and the carb will leak fuel. Before making an adjustment take a straight edge and place across the carb body just above the metering fork. The fork should be exactly parallel or slightly out from parallel to the straight edge.
NY
the butterfly is right, I did find the timing off by about 2 deg. it s.b 6 and I measure about 4 I wonder if that's the issue? this is a brand new walbro wj71.
Here’s an exploded view of the carburetor. Notice that the diaphragm, item 29, is against the cover with the four screws not the body of the carburetor. Dan.
http://wem.walbro.com/walbro/product...71-1&Series=WJ
NY
on the carb, it's new.should be good for 100cc engines. can they be defective? have people had this kind of issue before? as to the timing, that is from the zdz/troy bilt web site.this is a rotary valve engine, not the usual reed valve. don't know if that makes a difference.
If the engine had been run before it sat around for a while, the diaphragms may have deteriorated during that period of time. It’s not that difficult to change them and check the carburetor while you’re doing it. That timing still sounds strange. There are plenty of guys watching this forum with more experience than I have that can comment about it. If it is correct, make sure you are using an ignition module that is timed to run at that firing angle. Dan.
My Feedback: (41)
Not actually it isn't unusual, it's a measurement between two points in mm not degrees....
For the OP; I suppose it's possible that the timing is an issue but I'm not sure about that being the problem. I have found that my ZDZ's like 6.5mm on the timing and they are cold blooded. Once started they need to warm up some before they'll play.
NY
yes and yes. the cowl is off. the throttle shaft is marked and the choke is visible. I have quite a few gasers and never had this before. all the other engines are da's tho. I,m leaning towards a bad carb, even tho it's new.i didn't have this issue with the old tillison[but it was a pain to start]
IL
I just read this and the first thing that came to mind was not a defective carb, but, a defective carb installation. Particularly I would first check that the crank case pulse pressure to the walbro's pump side is not blocked missing or otherwise wrong.
My Feedback: (41)
If all that is correct, I suppose an air leak might be causing the issue but it would have to be a dandy. You could fatten up the top end needle a bunch and see if it will accelerate as a test? The only other thing I can suggest is that you try contacting Dick Hanson via PM either here, FG, or RCGroups. He knows ZDZ engines really well and used to be part of ZDZ's development team and a beta tester for their engines.
NY
zeeb, top end needle opened to where it was off the spring tension[more than 5 turns] and still the same. of course it quit when it came out, and again, the idle is perfect. I ordered another carb just for fun.
NY
so, I wonder what crow taste like? reread all your posts again. got out the flashlight and got into the back of the engine in the fuse and had both carbs in my hand.after a while I found the issue. I mounted the carb upside down. the pulse holes were 180 deg apart. how it ever ran and started is a mystery to me.must be my 65+ years. I,m sure it will run fine now. thanks to all.
My Feedback: (41)
Wish I had a picture or two but I don't so I hope that helps.
My Feedback: (41)
Again, I've never had the Super 80 so it might be different than mine but I suspect not. That being the case you have to be able to see both sides of the block as it's only cut on one side. If that block is installed backward it won't play. If you cannot see the slot/channel with the carb off I suspect the block is on backwards since that channel/slot has to be toward the carb.
My Feedback: (41)
Well I just tried to find a parts/maintenance manual for your engine and ZDZ has dropped the old website which had diagrams and parts lists for all the engines. That website and even the domain name for the English version is up for sale.
I guess you could try calling TBM if this last possibility doesn't turn out to be the issue but I've not been impressed with TBM every since Gene quit running the business and hired a manager. Were it me, I'd be calling AMR who is the Canadian importer/distributor for ZDZ.
NY
maybe I,ll pull the engine and check.however, as this is one of the few arfs I bought there are pics in the manual of the zdz super 80 installed and it clearly shows the carb installed. I had it in with the needles on the wrong side which backed up what I found. the plane is the aeroworks 85cc yak and the manual is on their site
NY
zeeb, ok. heres the deal on the block.yes it's on right because the mounting screws into the crankcase are recesed on only one side.they have to be flush with the carb side. bob I took off the block anyway. there is a short, maybe 3/8" long slot to line up the port in the crankcase with the hole.but that has to be on the inside to line up.so, yes, I had the carb on upside down!
My Feedback: (41)
