How do you set up a gas engine fuel tank?
My Feedback: (25)
I bought some weed eater conversions a while back. I can't get them to run or even try to run. How does the fuel routing system work? There is a clear red primer with a separate supply inlet. There is also another inlet for the carb. Do these both come from the tank-Teed off? I'm using the yellow fuel line I got from our local small engine supply vendor. I tried to search this but came up empty. I don't have a weed eater to copy from. All help appreciated! Thanks, Tracy.
