2 Stroke gas/oil exhaust temperature
My Feedback: (64)
Anyone have an accurate measurement of temperature as measured @ the exit of an exhaust header going into a tuned pipe??? I'm interested in the temperature requirements for an epoxy resin to form a carbon fiber pipe. Don't think it makes a lot of difference but, I'm in the 30 to 60cc range.
Thx
Thx
Around 1100 to 1200 degrees Farenheit if the mixture is right. Plan for a little higher. Four strokes can run over 1300.
Actually, I misread your post and thought you meant at the header to exhaust port area. At the end of the header it would likely be a little less than I stated.
AV8TOR
AV8TOR
