Brison 2.4,, parts??
Bill Jenson's website says he is still selling parts but not servicing engines . I would contact him first then try kangke usa as they are the primary seller of Brison
http://www.bj-model-engines.com/
http://www.kangkeusa.com/gasengines.htm
More than likely the loss of compression is a stuck ring if so I would contact Frank Bowman for new ring(s)
My Feedback: (16)
Caber rings are the world standard. They are available from many sources in the USA. They are made in Italy. I just happen to get mine from either Greece or Israel. Takes a couple weeks.
Due to current events in Greece - - It might be best to source them from the USA?
You can make you own by using an rcexl sensor and setting it in epoxy resin . I used a straw of the correct I.D as the form and just cut the straw away after the epoxy cured.
My Feedback: (19)
Glad to hear your 2.4 is back in running condition. Darn good old engines!
My Feedback: (158)
yes, I did that once with the rcxp sensor and ignition after the original one smoked,, for some reason the pick up went bad, I can get one from tower for the DLE cheap, but I bought a new oem mechanical advance ignition, I was going to put it back to the stock set up. I need the one that's the end cap design,, Hoped some one has one laying around they don't need.
