Rcexl is always on
Old 03-27-2016, 03:03 AM
jayps72
jayps72's Avatar
Exclamation Rcexl is always on
when i connect 6.6V LiFe as input to the Rcexl optic switch( running on a 30cc gasser plane) the red indicator is always on. i did connect the rx lead in to my JR12Rx on a "Gear" channel but the switch does not switch off
Old 03-27-2016, 04:35 AM
Gizmo-RCU
My Feedback: (27)
I have mine on the gear switch on my 9 channel Hitec, had to reverse the channel and all was good! About drove me nuts until a buddy suggested that change. Don't know if that helps
you? Worth a try.
Old 03-27-2016, 04:41 AM
jayps72
jayps72's Avatar
mine is a JR..let me try,
I also see another problem...engine firing is regular and see the RED LED flicker abruptly?
(i have powered the RCexl through a mechanical switch but i will will not fly until the problem is rectified )
thank you Gixmo-RCU
Old 03-27-2016, 04:42 AM
ahicks
Not familiar with the JR, but willing to bet you have a setup issue as well. Do your switches require they be enabled and assigned to be functional?
Old 03-27-2016, 04:45 AM
jayps72
jayps72's Avatar
let me reverse the gear channel and try...get back to guys soon
Old 03-27-2016, 05:13 AM
flyinwalenda
flyinwalenda's Avatar
Go to the monitor screen and make sure the gear channel is working/moving when you operate the switch. If not then as mentioned, it may not be enabled or mapped correctly.
If it is enabled and reversing doesn't fix it then adjust the endpoints to the max for the gear channel and try it.
