BME 50cc engine
ON, CANADA
BME 50cc engine
The above engine just quit during flight and I could not start it again. I never had any problems with it previously. I noticed that it was not pumping any fuel. I examined the carb and even though it was clean like new, I still cleaned it and replaced the screen, the pump diaphram as well as the metering diaphram and it still does not pump fuel. What else could be the problem? Would there be any problem with the engine itself other than the carb? It has plenty of compression. Any suggestions would be most welcome. Many thanks.
Hi,
Sounds like a blocked passage somewhere.
It could be a few things.
First is the pulse port in the engine and/or carb clogged or partly covered by the carb to engine gasket ?
Did you remove the high and low needles and blow them clean with air or solvent ?
Last thing would be ,with the needles removed, to remove the Welch plug in the carb clean inside then run a very fine wire through the ports/holes. Make sure to replace it with a new plug cover from the kit.
Have you checked the fuel lines for kinks , etc... I would pull the fuel line off and Run a fuel line straight from the carb to another gas tank or fuel can and see if it will pull fuel . If it does pull fuel then the problem is in your tank or lines. If it still will not pull fuel then I would remove the carb and the carb isolator block and inspect the gaskets for proper positioning and / or a blockage or more likely a crack near the pulse passage .
My Feedback: (10)
