14mm- 10mm brass plug adapter
Reply
Old 12-19-2017, 10:02 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 14mm- 10mm brass plug adapter
I recently installed a brass 14mm-10mm brass plug adapter in my Zen engine and it runs just as well as before with it's now smaller CM-6 plug. Due to the thickness of the adapter the plug tip does not extend as far into the combustion chamber as before.
My question is this; has anyone ever run a spark plug without it's usually supplied crush washer without having any leakage issue ?
karolh is offline
Old 12-19-2017, 11:01 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used taper seat plugs in non-taper seat heads with good results but that doesn't apply here. I've flattened the washers before in automotive applications where I wanted to index a plug but I'm not sure that would help enough to lower the plug into the insert. Heck if it starts and runs as expected, I'd just leave it alone.
Truckracer is offline
Old 12-19-2017, 11:08 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why try to re-invent the wheel.......think I'll take your suggestion and leave it alone.
karolh is offline
