Smoke pump interference??
I'm just curious about any possible RF interference issues with the various electric smoke pumps out there. Any issues encountered? How about with 72 MHz?? Is it necessary to "break in" the brushes as was often done with brushed car motors? Dare you hook one up to your flight battery?? Any thoughts, and better, experiences would be appreciated.
AV8TOR
AV8TOR
I've run the TME and the Sullivan on both 72Mhz and 2.4 without break in or interference . Both units were already suppressed . I did not run them off of the receiver pack .I always ran them off of the ignition pack or a dedicated pack
If youre havinf RF issues maybe the motor suppression has failed . You could ad capacitors at the motor can like back in the old car days . I'm not sure what size capacitors tou would use on the Sullivan motor it pretty small .
If youre having RF issues maybe the motor suppression has failed . You could add capacitors at the motor can like back in the old car days . I'm not sure what size capacitors you would use on the Sullivan motor it's pretty small .
Thanks for the answers. I ask out of curiosity, plus the fact that I have a brushed speed controller lying in a drawer, and one of those 16 dollar Sullivan "Streamer" smoke oil pumps. You can see where I'm headed with that.... A lot cheaper way to set up a smoke system on another plane than my 80 dollar "Skywriter" system.
On yet another plane, I have a smoke system with a little pump I made by sawing a Walbro carb in half. Works great!
Anybody have an idea on the value of the capacitor a person should use? I imagine a range of values would work.... And it's one across the poles, and one from each pole to ground, right??
AV8TOR
AV8TOR
OK, thanks a lot for the info! My Sullivan Skywriter doesn't say anything about breaking in the motor; only that you should be sure to run it on sufficient voltage for the first 20 minutes until the head unit itself breaks in. I think I will set it up to recirculate through a tank and break it in before I fly it. (I tend to be a bit "anal" at times.)
Thanks again,
AV8TOR
Thanks again,
AV8TOR
I usually run new smoke pumps for 5 minute on time intervals . Recirculating oil with large tubing for low fluid resistance. I run 5 minutes on then 10 minutes off untill I reach at least 30 minutes run time. This way the motor gets broken in without overheating it too much .
