RCGF 10cc exhaust header
Thank you! I completely forgot about MECOA. Unfortunately their MAC headers are $40 to $60, and shipping to Norway is $15 to $19, so I might end up paying more than $70 for a header. It might be worth it though. I couldn't find anything on eBay, but I'll keep looking.
Good idea! I found one engine that has the same exhaust port dimensions: Moki .61 LS (28 mm bolt spacing). Most engines of similar size has a longer and narrower exhaust port with 35-42 mm bolt spacing. Now if I could find a header (or silencer) for a Moki .61 LS. Maybe a stock .61 LS silencer would work well? I don't need to get maximum power out of the RCGF 10cc, just trying to make it quieter. If I can find a header, I will use a home made spray can canister, but a regular silencer would probably work equally well.
