DLE Thr. arm spring
Reply
Old 04-15-2019, 06:01 AM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default DLE Thr. arm spring
I bought a Ultra stick lite , with a DLE 20 on it. The DLE never ran very well.I just put a new Carb. On it and it is running great.But I notice , there is a spring on the THR, arm on both carbs. I would like to disable the spring to cut down on battery draw. Just wondering if that will cause a problem?
Stick 40 is offline
Old 04-15-2019, 06:54 AM
mogman
mogman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On a lot of my planes I use a piece of kevlar cord (or similar) to open the throttle and let the spring on the carb close it.
Works very well. There is MINIMAL resistance leaving the spring on the arm.
If you do decide to remove the spring, just unhook it from the arm, but leave the spring in place. It helps to keep the throttle plate centered and stop vibration that causes wear on the throttle shaft.
mogman is offline
Old 04-15-2019, 06:55 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Disabling the spring won't create an issue as long as it is still there to apply a slight side load to the throttle plate. If the throttle plate is free to vibrate sideways it will create mixture fluxutions. I left the spring attached on my last tow gas engines. It really does not load the servo all that much and having it loaded did seem to give a little more positive throttle control.
speedracerntrixie is offline
Old 04-15-2019, 11:38 AM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some years ago I published tests on how much current a servo draws holding against a throttle spring. The test involved a number of different servos and Walbro carb models. The conclusion was that a servo draws very little current while holding against a Walbro throttle spring. There is simply no reason to cut, disable or remove a throttle spring as there is nothing to be gained by doing so.
Truckracer is offline
Old 04-15-2019, 02:08 PM
Stick 40
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
good, thanks for the reply's. I will leave it .
I was trying to fix the first post with the sp and some how reposted. LOL
Stick 40 is offline
