Evolution 10gx Carb cleaning.
Reply
Old 05-23-2019, 11:32 AM
Chefia
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Evolution 10gx Carb cleaning.
Hello, guy.
I have a Evolution 10gx grounded for 3 years after lot flights. Now I go put my plane to flight again. But I need change the fuel lines and cleaning the carb. If I can't find the set of this car gaskets for sale anymore, and never open this carb. Anyone can tell me if I can open and cleaning the carb without need change the gaskets o-rings or others parts? Or can I use a spray carb cleaner?
Thanks.
Chefia is offline
Old 05-23-2019, 11:57 AM
deason
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Chefia View Post
Hello, guy.
Thanks.
What kind of carb is it? If its been sitting that long you will need to rebuild. You can find just about any carb kit here - https://www.ereplacementparts.com/
deason is offline
Old 05-23-2019, 12:20 PM
Chefia
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE=deason;12526883]What kind of carb is it? If its been sitting that long you will need to rebuild. You can find just about any carb kit here -
Is that carb:
Horizonhobby.com/carb-assembly%3A-10gx-evog10801
They sell this rebuild kit but is not available.
horizonhobby.com/carb-gasket-set%3A-10gx-evog108a
For is not available I ask if someone open this carb an cleaning without need replace those parts.
Chefia is offline
Old 05-24-2019, 03:27 AM
ahicks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Really not much going on inside that carb. I would make sure the spray bar is clean and leave the rest alone. There is a little green gasket under the gas inlet fitting that should be checked. They like to break down/decompose and start sucking air at that point. You can make a new one out of about anything that's gasoline proof. I used a gasket cut from a milk jug for my last one.
I don't think anything inside would need to be replaced if you did want to take it apart.
ahicks is offline
Old 05-29-2019, 12:12 PM
Chefia
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I go open and see what's need change.
Chefia is offline
