old bme 58cc walbro recommendations
TX
any info of old bme 58cc engine, walbro recommendations or other make carburetors to replace the walbro wa 200 it has. Not having good idle with it. Nor enough on high end either. Lowest idle is 2400 rpms and highest is 5900 rpms with a 20 x 6-10 prop.
Thanks in advance
Thanks in advance
KS
Are sure it's a 58 and not a 50 my 2 58s will prop rip a 23x8 and a 50cc pulls a 21x10 or a 22x8 there is also a 44cc it pulls a 20x10 or 21x8 the 44 and 50 are beam mount and the 58 is mounted on stand offs.
KS
If it is mounted on a mount like a glow engine and bolted to the firewall it will be a 50 cc or a 44cc. Try setting the low speed needle at 1-1/4 and high speed to 1-1/2 out and adjust from there if either of the needles are out much more than that that's probably your problem.
